Results 1 to 10 of 13
Thread: Double din surround for Xenarc/Gain screen
    Newbie Scarum's Avatar
    Cambridge, UK
    I have seen a double din surround for Xenarc/Gain screen somewhere (on here perchance?) but for the life of me can't find it again. Does anyone know what I mean?
    Maximum Bitrate srcstc's Avatar
    Dec 2003
    New Jersey
    Do you mean something like what I made for my car??
    Rich
    Cambridge, UK
    I've seen you creation already, and very good it is! 10 out of 10.
    But I saw something manufactured specific for the task, would be for a VW Golf MK IV. Where did I see it, I thought I saved it as a favorite nut no go.
    Dec 2003
    New Jersey
    Quote Originally Posted by Scarum
    Is this what you want?
    Xenarc Headrest Shroud
    http://store.karpc.com/item-Xenarc-H...oud--700shroud
    Cambridge, UK
    Yea yea yea! You diamond geazer!
    But I thought I read somewhere this was for double din fitting... guess I was wrong.
    Thanks anyway, back to the drawing board!
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    I don't think so.. A Xenarc with the houseing is big (height) enough to fit if a double DIN....With the shroud it won't fit at all!!
    Cambridge, UK
    That's OK, just get rid of drinks holder!
    Variable Bitrate Pabs's Avatar
    May 2004
    Somewhere in the UK
    Dude, the xenarc is SO CLOSE to fitting in a double din size.
    I have taken a Double DIN facia for my car, and have managed to use the above mentioned shroud to glue it to the facia. I am now in the progress of tidying up the glue-work and making it look stock.
    From my measurements and knowledge, i came up with this:
    xenarc dimensions:
    195mm wide X 122mm height x 35mm thick/deep
    (7.75inches wide x 4.75inches height x 1.33inches deep/thick)
    Single DIN = 60mm height x 190mm wide x 170mm deep
    Double DIN = 120mm heightx 190mm wide x 170mm deep
    So, the height is only around 2mm too big, and the width is only 5mm too big.
    Correct me if i am wrong, but with a little filing here and there you can get it in?
    I will keep peeps up to date on here with the install as it progresses!
    Jun 2004
    an invader from the SEATCupra.net forums!!
    Cambridge, UK
    Nice one Pabs, those dimensions refine the thought processes going on!
    Yesterday I thought about getting two of the OEM Golf cubby holes and combining them to make a double din cubby hole into which the screen is fixed. The cubby holes will click into place within the fascia so easily removable.
  1. Looking for double DIN 7 x 4 epia case
    By pieter3d in forum Newbie
    Last Post: 06-22-2004, 06:34 PM
  2. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  3. Replies: 13
    Last Post: 07-02-2002, 11:54 AM
  4. LCD size for double DIN ???
    By infinitiqx4 in forum LCD/Display
    Last Post: 04-14-2002, 09:28 PM
  5. NEC Versa M/75 Laptop TFT screen w/touch
    By Macgyver777 in forum LCD/Display
    Last Post: 03-24-2002, 03:14 AM
