Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Latex Moulds?
    Low Bitrate PotzUK's Avatar
    Jun 2003
    Bristol, UK
    Latex Moulds?
    Hi all,
    I've managed to modified the center console of my dashboard to make room for my Gain display (http://www.pyroport.com/carputer/images/dashmod/). I've made a latex mould of it no probs.
    I'm just a little concerned about whether I can get away with fibreglassing the inside of this mould? Will this work? How easy will it be to remove the latex mould?
    Dec 2003
    Im having trouble figuring out which part is the mold. Is it the white stuff? Anyway, im not certain how the resin will react with the latex. I think latex is a plastic polymer of some sort. So I think it would be ok. Your best bet is make a test piece and throw some resin on it. If the latex reacts with the resin. I would suggest coating it with some spray on wax or lining it with tin foil. Good luck!
    FLAC Spaghetti's Avatar
    Jul 2003
    Spagcave, in da UK Today's phrase: J'aime Alizee
    You'll melt the latex, I'm pretty sure. Why don't you use fibreglass to make your mould? It'll be a bit more work, but it's ultra-rigid and better for defining forms. If you're unsure about using fibreglass, you could use plaster for the mould then fibreglass for the final cast
    Jun 2003
    Bristol, UK
    You're kidding right?
    I spent a week making this latex mould!
    I thought latex would be OK, as people wear latex gloves with fibreglass/resin all the time?
    Tred: Sorry, those pics show the dashboard part, not the mould. The white areas in those pics are milliput I used to fill the gaps.
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    you ask for help/opinions then argue the responses?
    read this slowly:
    •Micke
    Dec 2003
    From my knowledge I think latex is pretty flexible. So even if you do spray on some wax it might be hard to fiberglass over it. You could always use some plaster to make a mold of your latex mold. Plaster curing time is pretty quick and it wont react with the latex nor Fiberglass resin.
    Dec 2003
    Quote Originally Posted by grepzen
    read this slowly:
    i dont think hes arguing man. just venting his frustration.
    I think it will turn out ok in the end.
    Jun 2003
    Bristol, UK
    No, I asked if it was possible to fibreglass the inside of a latex mould that I have made from the modified dashboard section.
    Jun 2003
    Bristol, UK
    Quote Originally Posted by Tred
    I was hoping that I could apply a layer of resin/hardener on its own bit by bit to give the rigidness required to then apply the fibreglass.
    Jul 2003
    Ok, I think I might've misunderstood the latex bit. I can tell you that I have used SILICON moulds before (not cheap) and used a quick casting two-part resin to make some small model parts at uni.
    Looking at your pics, it's hard to imagine what you're trying to do. Are you making the original form in filler/glassfibre then taking a mould to create a single final cast devoid of heavy filler?
    Isn't latex porous? I'm not sure about latex gloves, but I'm sure they're not simply made of just latex.
