Results 1 to 9 of 9
Thread: Foam?
    Newbie Slimline's Avatar
    Nov 2004
    Arlington, TX
    Arrow Foam?
    I was reading through here
    and saw they used heavy foam stuff... My question is, where do I find foam that consistent and durable? I'd like to use it to create a mock up of what I'll be doing, or even use it to form the fiberglass. I've never done this before, so be gentle
    Low Bitrate KMorphosis's Avatar
    Aug 2004
    Faw from heyar...
    Aug 2004
    Faw from heyar...
    Also check out www.selectproducts.com
    go to fiberglass, then fiberglass accesories.. towards the bottom of the page they have Wonder Foam..
    Nov 2004
    Arlington, TX
    Arrow
    Bookmarked! Thanks!
    Constant Bitrate dexy's Avatar
    Jul 2004
    NY
    In homedepot, I bought 2 types of foam, 1 is a softer type, called ("great stuff") or something like that. Then there was this one called "HILT", That thing is so strong when it dries, it can hang a brick off a wall.
    Jul 2004
    KMorphosis, what 's Wonder Foam?
    Aug 2004
    Faw from heyar...
    Its the name of the product. I haven't used it myself, but I think it is about 10 lbs Poly Foam. It can be used to make forms for Fiberglassing over.
    If you are looking for foam that you can sand and then paint by itself and use for interior body panels or for custom door panels I would go with the first link. There you can get your estimate on how much it will cost to do your project.
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Small quantities of urethane foam are available here. You will need urethane foam if you plan to fiberglass over it, and its very expensive. The nice part is that once it's glassed over you can scrape and sand the foam from the backside and end up with a very nice part. Polyester resin will melt any other foam, so the cheap stuff you find at the home stores will not work for this purpose.
    Fabricator
    Low Bitrate PHiLiSO's Avatar
    Oct 2003
    detroit
    How in the world would you put the special AirPort card in a PC? Mine is a Mac anyway but it's too old to AirPort. I just use a zip drive to transfer.
  1. Foam to use as a base in fiberglassing, bondo work, etc.
    By imprezive one in forum Fabrication
    Last Post: 10-04-2006, 11:26 AM
  2. Foam
    By bmwperson in forum Fabrication
    Last Post: 09-15-2004, 05:35 PM
  3. Before you use foam to mount your Touch Screen
    By NewTechFool in forum LCD/Display
    Last Post: 03-05-2004, 02:33 PM
  4. Mounting in foam
    By Tha Hombre in forum General Hardware Discussion
    Last Post: 02-21-2004, 09:53 AM
  5. Fiberglass over foam?
    By gork in forum General MP3Car Discussion
    Last Post: 08-20-2003, 06:57 AM
