Results 11 to 20 of 26
Thread: How-To: Install Large Headrest Monitors
  1. #11
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Well this is the only car I've installed headrest monitors on and it had hollow posts. I guess Nissan is a little more weight/performance-oriented than other manufacturers.
    Fabricator
  2. #12
    Mar 2005
    CT
    WOW, that is a great install, hoping to do the exact same in my PT cruiser, so you are using 6.5 inch TViews w/ 4:3 aspect? Also how did you run the wires down through the seat to get to your main source and what not. Also would you be willing to install mine if i sent them to you? and how much would you charge? thank you
  3. #13
    Mar 2005
    Altimat thnx for the best write up on how to install over sized monitors I have ever seen... just had a pair of (Clarion VMA7194) 7" monitor installed in a 2k5 Maxima headrest
    Without your detailed info, don't think I would have been as clear to my installer what
    or how I wanted it to look (shout out to Danny u da Man)
  4. #14
    Oct 2003
    WI
    Thats what I like to hear!!! Thanks!
    Fabricator
  5. #15
    Jun 2005
    Quote Originally Posted by coachreed
    Why does it look like the wires are going down through the tube on one but not the other? I'm just curious... none of the cars that I've done headrest monitors on have had hollow headrest tubes. Were yours hollow or not?
    I think what you are seeing is the plug end of the cable. I looked at the picture and it looks like the cable is looped and the end is under the car seat.
  6. #16
    Oct 2003
    WI
    Yes, being a high performance make , Nissan headrest tubes are hollow. I had to cut the connectors off to get the wire through though.
    Fabricator
  7. #17
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    How much would you charge to do something like this in a 04-05 Maxima?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  8. #18
    Oct 2005
    Quote Originally Posted by tbird2340
    bringin up an old post i think but i'd like abit of info..
    if this is connected to a carputer how would u power the screens.. do they come with on/off button?.. how do u put the display from the carPC on 2+ the one front screen.. ive looked around but cant find anything ... help appreciated
    yes ive and but no luck :P
  9. #19
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    i have a video card that has vga and s-video out. run the lcd's off the s-video and just power them from the yellow and black wires on your power supply
  10. #20
    Aug 2006
    Nosssa que coragem,,, estragar um encosto de cabeça....
  1. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 04:41 PM
  2. now you see it now you dont 97 yukon install
    By FAmonmouth in forum Show off your project
    Last Post: 05-04-2005, 10:43 PM
  3. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
  4. Headrest Monitors DIY
    By [iG] in forum Fabrication
    Last Post: 06-27-2004, 09:15 PM
  5. suggestions on headrest monitors?
    By kaotic504 in forum LCD/Display
    Last Post: 01-20-2004, 02:03 PM
