Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Bondo won't Dry! Just Stays tacky!
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    Yeah, I've been working on a console piece for my car thats gonna have a touchpad for a laptop and some buttons and various other things. I've molded my touchscreen into my dash before and have done that for a few friends too, so I know how to use bondo fairly well.
    But my problem: This time around the last couple of nights I've worked on this the bondo remains really tacky, or it will be weak and I can sink my fingernail into it and pull out a chunk. I am pretty sure I've got the consistency of the hardener/bondo right. I even tried putting extra hardener in and putting less than I was supposed to. This still didn't help. I've tried putting the bondo'd console right under a halogen lamp and putting a blow dryer on it to see if that would help. It did dry a bit faster, but still not quickly and it still didn't get untacky. The only thing I can think of now is maybe it's the weather? It is a bit chilly and I've noticed the tackyness being pretty bad now, which may correlate with the humidity, which is terrible right now.
    Current Weather conditions:
    57°F
    Cloudy Feels Like
    57°F
    UV Index: 0 Low
    Dew Point: 54°F
    Humidity: 89%
    Visibility: 10.0 miles
    Pressure: 30.18 inches and steady
    Wind: From the East at 7 mph
    I think it was only 40% humidity the other day and it was still tacky >.< Any suggestions on how I can get this project done? This is driving me crazy! I keep having to peel/sand all the bondo off and redo it!
    CarPC install is starting to come along again...
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    It needs to be warmer, can you do this in a heated basement or something.. it needs to be like 70 (at least) for it to harden correctly... :-\
    I'm not sure if you know what the finished product should feel like.. but it should feel like "plastic" remember those plastic army men ?? It should feel like that...
    Addition:
    If your bondo was stored outside.. and was cold before it was hardened that also might have ruined it, maybe try gettin a new canister of bondo (if you can afford it)
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    May 2003
    Texas
    Cold weather makes for REALLY slow drying times. As long as you put hardener in there, it will dry eventually assuming that the bondo and hardener did not go bad for some reason. Keep it in heat, and just give it more time.
    In the summer, the bondo can get VERY hott to the touch when it is drying. It is the actual heat in the air and that the chemical reaction generates that allows it to cure properly.
    May 2004
    Arkansas
    Quote Originally Posted by IntellaWorks
    Ahhh, nah I don't have a basement and I can't do it inside >.< Maybe I can go to my uncles shop, he has one of those oldschool stoves you put wood in...
    Yeah, I know what it feels like. I did a lot of bondo work during the summer that turned out great
    Addition:
    Really? It could actually ruin the bondo? Well damn I just bought a brand new can, and there's no way i'll be able to convince my parents to let me store it where its warm Well I did notice that the surface of the bondo had a really really thin film of a clear liquid, maybe not even noticible hardly. I wonder if it "seperated" or something? Because yeah this stuff is definately not hardening right. I just added almost double the amount of bondo you're suppose to add and put this thing under a halogen lamp and hair dryer again. I'm hoping it'll be warm enough to make it harden.
    So in short I should go buy another can and go to a place where it's warm?
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Ummmm.... if you keep all the receits like me then you'd go and exchange that can
    May 2004
    Arkansas
    thats half used and with bondo dripping all down the sides? rofl that would be funny but they would be like uhh no. the guys at my autozone are assholes, and its only $5 so i wont ***** anymore
    May 2004
    Arkansas
    strange thing happened guys...i've been going out and checking on the bondo and getting bummed that even tho i have heat on it its not getting any harder. so i went out there just a sec ago once more and pressed my fingernail into it, still soft. so i take the halogen lamp and turn the hairdryer that was pointed at it and on off. read the bondo can looking for a place where it says it will get ruined in the cold and the temps and stuff (which btw it says best results if its above 45degrees farenheit). Then after readnig that the console had time to cool down. and now its hard. pretty hard, not perfect, but a much better improvement. If i really push down and hard i can dig off a piece of the surface. any comments?
    May 2004
    Arkansas
    damn. i thought all was well. after the last post i went out and felt it again and it was hard as a rock, i couldn't scratch it off or dig into it or anything. i started sanding and been sanding for a while with my electric palm sander for like 5 mins, got down to where i started shaping it nicely and i decided to feel the surface and guess what? I'm able to dig into it again and i can peel it off. it's tacky like before! WTF?! is it because it got cold since it was off the lamp that it got soft again? surely not! maybe the layer beneath didn't cure because the heat only hit the surface? I put the lamp and hair dryer back on it. Oh I should note that the thickness of the bondo was about 1/8" to 1/4"
    Jul 2004
    Berkeley, CA
    What kind of bondo is this? The fibre reinforced or just filler?
    New York
    Well, thats cause when you dried it, you only dried the outside layer and never gave the inside a chance to dry. But to tell you the truth Grayscale, if it was me, i'd remove all that bondo work. For strange reason, and I had it happen to me once before with Fiberglass. If it just doesn't harden, and isn't getting harder after like 15-20 minutes, then its no good. On that bad batch, even 1 month later it was 'ok' but never hardened like what your explaining.
    Get new bondo, new hardner and see what happens. I just did some bondoing work today in NY, the garage temp was 57deg with 100% humidity, kind drizzling today, worked fine.
  1. Foam to use as a base in fiberglassing, bondo work, etc.
    By imprezive one in forum Fabrication
    Last Post: 10-04-2006, 11:26 AM
  2. bondo and plastic.
    By dannn in forum Fabrication
    Last Post: 01-04-2005, 11:20 PM
  3. bondo question??
    By boomboom in forum Fabrication
    Last Post: 07-19-2004, 09:58 PM
  4. fiberglass or bondo??
    By faiz_23 in forum Fabrication
    Last Post: 05-04-2004, 07:39 AM
  5. OPUS 150 watt, USB stays powered???
    By GScherler in forum Power Supplies
    Last Post: 12-19-2003, 03:44 PM
