Page 7 of 8 FirstFirst 12345678 LastLast
Results 61 to 70 of 80
Thread: How-To: Recessed Screen and DVD Drive
  1. #61
    Variable Bitrate DaveB's Avatar
    Mar 2004
    Is it necessary to glaze over the inside the wooden frame before painting it? It seems like that would be hard to do. It would be tough to sand and get clean edges on the inside corner.
    Do you leave the back on the Lilli or remove it for ventilation?
    When you bond the Lilli into the frame, I assume you do it from the back. If the back cover is on the Lilli when you bond it, then how do you paint the Lilli after its in place given you can't disassemble the Lilli?
    8" Lilli TS
    MB896F Mini-ITX MB
    2GHZ Dothan 533MHz FSB CPU
    1GB SDRAM DDR2 533
    Seagate 300GB SATA150 HD
    ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
    Pioneer Slot Load SLIM DVDRW
    Bluetooth V2 USB 2 Dongle
    3COM BKP Cam
  2. #62
    Tainted Love Cris's Avatar
    Romania
    Quote Originally Posted by DaveB
    This operation requires you disassamble the screen, you can't really do it this way, otherwise.
    It's up to you if you want to put the back of the screen on...depds on how much ventilation you have back in your dash. I for one, didn't put it on.
    Looks carefully at the pics. You'll now the steps involved.
  3. #63
    Jan 2006
    krylon fusion?
  4. #64
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    You can disassemble the Lilli. Just remove everything from the back of the front bezel but do not mess with the LCD ribbons.
    The bare woodgrain does need to be sealed either with a layer of filler or with a good, slow hobby epoxy so the woodgrain doesn't come back through the paint (Learned this the hard way).
    Fabricator
  5. #65
    Mar 2004
    When you bond the front bezel of the Lilli in place how do you go about bonding it? In other words, where do you place the glue? If you put glue on the back outer edges of the bezel you would never be able to put the back cover on again, correct? I'm assuming that may be why most people leave the rear cover off.
    8" Lilli TS
    MB896F Mini-ITX MB
    1GB SDRAM DDR2 533
    3COM BKP Cam
  6. #66
    Romania
    I put mine on the sides, and a little more on the back. The back can fit with the glue on. It won't look good, but then again, it doesn't have to.
  7. #67
    Feb 2006
    hey guys, i'm looking at trying this out myself over the weekend, but I'm having a hellofatime finding Evercoat Metal Glaze. Are there any substitutes I can look for that you might recommend, or some place I should be trying to find this stuff? I've tried a few auto parts stores, ACE hardware, OSH all to no avail.
    Also, when I am looking at paints, do I need anything specialty? (I continue to look for PlastiKote, but so far no luck) I assume that since I'll mostly be painting on the bondo/evercoat at the end that most any automotive paint will work ok. Am I mistaken?
    Thanks so much for a great write up on this project, Altimat. I'm very excited!
  8. #68
    Low Bitrate dfk70's Avatar
    Sep 2005
    Sterling, VA
    Quote Originally Posted by bmbr
    You'll probably have to go to a place that sells automotive paint and supplies to get Evercoat.
    2003 F-150 Harley Davidson Edition
    "The horse is here to stay, but the automobile is only a novelty - a fad." --- Marshall Ferdinand Foch, French military strategist, 1911
  9. #69
    Feb 2006
    well i used local.google.com to look for auto body supplies and after about 5 calls I finally found one that carries evercoat! everything's coming up milhouse!
  10. #70
    Oct 2003
    WI
    Your best bet it to get your paint products wherever you found the Evercoat. The commercial paints like SEM are way better than the consumer paints at auo parts, hardware, and home stores.
    Fabricator
  1. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 03:19 PM
  2. How to wire in External DVD drive and Screen
    By legend5761 in forum Power Supplies
    Last Post: 11-01-2004, 10:04 PM
  3. Deal alert: Mobile DVD Player w/5.6-inch Detachable Screen $99+5 shipping
    By mykolJay in forum General Hardware Discussion
    Last Post: 09-27-2004, 12:59 PM
  4. Make DVD fill screen under media engine
    By Mikesz in forum Media Engine
    Last Post: 09-24-2004, 04:57 PM
  5. Laptop/LCD screen hookup...
    By UrbanTacticz in forum LCD/Display
    Last Post: 11-28-2001, 05:49 PM
