How-To: Recessed Screen and DVD Drive
This screen is being installed in place of the original head unit, and will include a notebook tray-load DVD drive below.
Trial fit of the recessed housing constructed with 5-Ply Birch Model Aircraft Plywood 3/16" thick. It glues up quickly with medium CA.
The top is tacked with big, easily removed blobs of hot melt glue, and the bottom is secured with a couple of those nice little extra screws you have from removing the metal bracket on the back of your Lilliput. :) :
http://webpages.charter.net/Altimat/...n/DSC00035.JPG
The curved filler pieces on the sides are to fill two bulges in the plastic panel which matched the OEM head unit which had curved sides. They would look out-of-place with the rectangular screen. The recess above will be filled also.
This picture shows the sanding done on the backside before apllying epoxy for adhesion. Sand everywhere you will apply anything that you want to stick:
http://webpages.charter.net/Altimat/...n/DSC00036.JPG
Masked all of the seams on the front to keep the epoxy from bleeeding through. Epoxy sticks best, so I use a Kevlar reinforced type liberally on the backside to glue everything together and to reinforce all the wood seams previously glued with CA:
http://webpages.charter.net/Altimat/...n/DSC00037.JPG
Backside after gluing. I heat the epoxy with a heat gun which lowers its viscosity and makes it flow nicely and soak into the wood well. It also cures faster:
http://webpages.charter.net/Altimat/...n/DSC00038.JPG
View showing two little cavities I filled up all the way. You can't have too much strength and weight is not an issue here:
http://webpages.charter.net/Altimat/...n/DSC00039.JPG
Front view after filler work with the drive and screen bezel installed:
http://webpages.charter.net/Altimat/...n/DSC00040.JPG
OK here's the finished install:
http://webpages.charter.net/Altimat/...D%20Screen.JPG
