work looks sweet so far....keep us updated
Current progress.....
Thanks to everyone for their ideas that made this possible.
yeah it's looking good ... keep us posted and show us your progress... great work.
Test coat of primer. Just wanted to see exactly how much more sanding I need to do. I also wanted a better idea of what it is going to look like. As you can see.......lots of sanding left.
hahaha...LoL ... Are you sanding with a dremel or just a sand block?Originally Posted by Wolfman
I did the corners and buttons with a dremel. I also used it for rough shaping. Everything else is by hand with the foam type sandpaper. It's about 1/4" thick so I don't use a block. Too many hard spots for a block. Just slow and eyeball it a little at a time. I only have about 4 hours into it so far. I figure I have a couple of hours left not counting the re-install.
Well I think I am almost there. I don't like the finish though because it is too shiny. I love the texture.....if it was only ultra flat.
Looks really good - keep at it and keep the pictures coming.
Looks good. What do you plan on doing with the temperature controls? I've got the same truck. I'm not using a headunit. I placed the screen where the OEM HU was. I cut the temperature controller section and re-epoxied it on the bottom where the holder thing goes. I'll post pics soon.
Installation Complete, pics soon
EPIA M10000 in Morex 3688 case
FrodoPlayer
CoPilot Live 8
Back from long hiatus, will be rebuilding soon
