Results 1 to 10 of 11
Thread: What is the best finish for custom dash?
    Low Bitrate Wolfman's Avatar
    Nov 2003
    East Texas
    I am at the stage to finish my custom molded screen and was wondering what everyone else has had the best luck with. I have a very fine textured spray paint (looks like about 150 grit sandpaper when applied) but from testing it looks like it will be too glossy.
    Dec 2003
    SoCal - 909
    I'll get back to you in a couple hours. I'm trying plasticote flat black bumper and trim spray paint.
    AutoPC: M10k, WinXP, gps, wifi, 80GB HD, dvd-RW. SB mp3+
    MediaEngine front end, map monkey, netstumbler.
    gps mouse is on the fritz.....stupid technology
    FLAC Chairboy's Avatar
    Jan 2004
    In order of preference:
    1. The tanned skin of my enemies
    2. Vinyl from fabric store
    Chrysler 300 - Fabricating
    http://hallert.net/
    Dec 2003
    SoCal - 909
    flat black plasti-kote bumper and trim looks very OEM. at least for my honda, it's almost spot on in shine and texture.
    Constant Bitrate BassBinDevil's Avatar
    Nov 2004
    Vancouver Island, B.C.
    Polished, carved hardwood. Engine-turned billet aluminum or stainless steel. Plastics? Bah.
    Jan 2004
    It's been almost four years, I stumbled across this while researching which paint to use for my fabbed dash piece.
    Has anyone done anything with undercoating? I'm thinking it would be nice if I could have the sort of rubber-ish coat that the OEM piece had. Unless that's what the Plasti-Kote bumper/trim stuff above gives....
    http://hallert.net/
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Quote Originally Posted by Chairboy View Post
    just finished my dash using rubberized undercoating.
    The trick is to use multiple coats but thin coats or you will get runs. Also patience in between coats. Being in the last phase of my install I was a little over anxious and as a result I got a run down the flat side of the front finish. But it works great if you have a dash you used a lot of bondo on and have a few uneven surfaces. As I did, it was my first attempt at fiberglass and bondo so there were a lot of imperfections that the undercoating covered up for me.
    New Age Garmin - Skin for RR
    Jan 2004
    Thanks! I'll try that next if the next experiment doesn't work. I picked up some spray on tool protector.
    http://hallert.net/
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Sem Texture/Satin Black Paint
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: Exus28@aol.com
    May 2009
    How about exterior color paint? hnoes:
    You could get some spray can touch up paint, some nice clearcoat, and make the custom dash really stand out...
    EDIT:
    Whoops, i just realized I replied to a year old thread... O_o
    *grabs flamesuit*
  1. dash cover/ door idea
    By cyberpotato in forum Fabrication
    Last Post: 01-15-2007, 06:47 AM
  2. Help on custom dash for Caddy STS
    By Slaughterhouse in forum Fabrication
    Last Post: 12-14-2006, 07:47 PM
  3. FS: Custom dash for G35 sedan/coupe
    By Izik in forum Classified Archive
    Last Post: 07-24-2004, 12:39 PM
  4. temps in trunk vs dash
    By Saurk in forum General Hardware Discussion
    Last Post: 03-14-2004, 11:27 AM
  5. Replies: 14
    Last Post: 10-14-2003, 09:25 PM
