Results 1 to 10 of 12
Thread: Epoxy for PLexiglass
    Variable Bitrate HummDinger's Avatar
    Aug 2004
    Milwaukee, WI
    what is a good epoxy for plexiglass? I am about to try a new install and nex to creat a box shaped bezel and plexi glass is my best bet for now. I just am not sure what epoxy to get?
    You can still have something if you have nothing
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    I used this from Tap Plastics. I also bought this to apply it with.
    It works GREAT!!
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Constant Bitrate StationRocket's Avatar
    Sep 2003
    Rochester, NY
    more important than the epoxy you use will be the surface prep. It is very difficult for glues to get a good grip on very smooth surfaces. You can rough up the bonding surfaces with sandpaper or drill small holes for the epxoy to seep into.
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    I do not know if I remember this correctly but somehow I think chloroform is good to join two pieces of plexiglass together. put those two pieces together as you want to have them and aply chloroform using syringe on its joint. Let chloroform leak to joint and wait for few minutes. Just do not breathe too deaply
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Weld-On #4 or #16 works wonder. MEK also works well too and you can buy it from HomeDepot, Lowes in paint section.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Newbie Tequila's Avatar
    Oct 2004
    Quote Originally Posted by mpattonm
    I believe you meant Acetone, but that method doesn't provide as good a weld as acrylic cement does when applied in the same manner.
    Feb 2003
    SE, PA
    Yeah, weld-on rocks. It literally melts the two pieces together. The plexi will break before the seams. I built my case with that. The needle applicator is a must.
    I know weld-on contains MEK (methyl ethyl ketone) because they smell the same...not sure if thats all it is though.
    G945GLCF2 | 512MB RAM | 160GB HD | Holux GPS w/ Routis | XMPCR w/ TOSLINK mod | Audigy 2 NX | | Xenarc 700TSV |Opus 150W PSU.
    Dec 2003
    Isnt chloroform the stuff they use in movies to knock people out?
    Low Bitrate IonDokk's Avatar
    Michigan
    Quote Originally Posted by tbird2340
    It works GREAT!!
    I used this same stuff I got it from a local Plastics distributer as well as some pexi scraps, scraps to them are 14" and under made a kickin plexi box for my nehmiah. This stuf is what the pro's use and you can't break a joint the plastic will give first. As faa as surface prep it is virtualy nill just make sure it's free of oil.
    Epia M1000 1.2gig, Toshiba 40gb HD, Itronix 60gb HD, 512ram,PCR, Audigy2zs, 2 Xenarc 7" , FRODOPLAYER Trying RR frontend , 2@1600/w Harrison labs amps & Caps, Focal & MB-Quart midrange, Diamond Audio D6 Subs, Mb Quart Tweets, 2-Audiocontrol three.1 !
    Variable Bitrate 3g Jester's Avatar
    Nov 2005
    Lets get a bump on this forum. took a bit of searching to find this thread. i didnt want to start a new one if there was one already here....
    id like to know what other people had success with..where can you get those saringe applicators besides offline? i didnt see any at my local HD...perhaps Lowes? I tried a loctite epoxy.....and my box stayed together till i started mounting stuff...that sucked lol.
    i also heard the word "Araldite" mentioned in my searching...anyone?
