Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
Thread: Need Suggestions for Bondo'ing my LCD please.
  1. #31
    _
    Mar 2004
    Little Elm, Texas
    I could be mistaken, but I believe that that was covered under the FAQ for this sub-forum? At least I know it was covered in some thread somewhere in here
    you get teh bondo applicator...you know, those little paddle looking things that were right next to the bondo when you bought it?
    http://www.bondo-online.com/catalog_...sp?itemNbr=304
    Jan Bennett
  2. #32
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  3. #33
    Oct 2003
    Poland, OH
    I still have yet to finish this but I'm determinted to stop putting it off and hopefully finish this weekend. Here are some primered pics. I've circled some of the imperfections and wondered if anyone had any suggestions on how to fix them. If not, I will just live with them and put the paint on.
  4. #34
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    I definatly wouldn't paint over them, its going to stand out and **** you off. You've already put a ton of time (a year-ish) into this, might as well do it right. Get some bondo filler and some razor blades. Use small amounts of bondo filler and press over the dent / pin holes with the razor. Wait till the filler dries and sand over the filler with 220 grit.
    Once your finished sanding wash the bezel off with water you'll probably find more pin holes, repeat this process until EVERYTHING is flat. Then primer it again, sand the primer with like 800-1000 grit. Wash the bezel down and paint with your color...
    Expect to spend 20+ hours here.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
  5. #35
    Oct 2003
    Poland, OH
    Well, I haven't put the whole time from start to finish on this.. I just got lazy and didn't touch it for a LONG time.
    So, should I use the same bondo filler I used for the whole thing or get different stuff?
    Thanks for the help man.
  6. #36
    Jun 2004
    NH
    Definatly get a new tube. There's two types of bondo that you can typically find at say "Autozone" Bondo-Fiber (which is what you used to form that bezel) and Bondo filler.
    Bondo filler goes ontop of the bondo-fiber its way softer and less messy to work with. http://www.jcwhitney.com/autoparts/Product/tf-Browse/s-10101/Pr-p_Product.CATENTRY_ID:2000780/showCustom-0/p-2000780/N-111+10214+600010691/c-10114/TID-8014524
    It shouldn't be more than 3.50, but just really take your time. Thats where I always mess up. I see it comming togeather rush progress and realize everything looks like **** and have to strip it down and spend way more time fixing what I rushed.
    You might not get it done this weekend, honestly. If I were you plan to work on it just a little bit each night for the next week or two.
    This should be the process.
    10 minutes Putty
    10-15 Minutes Let putty harden (temp matters so make sure its at least 65F)
    5-10 Mins Sand
    5 Mins Wash (plain old water)
    15-20 Dry (it has to be completely dry before you add more putty, put it over a fan. To speed things up)
    ::Repeat
    As you can see its about an hour process and you can rarely cover every inperfection on the first run. Also, you'll create minor imprefections while going through this process that you'll have to fix on another interval. Yes, it sucks and it really takes a TON of time...
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
  7. #37
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    I used 3 types of bondo
    first the Bondo Hair with fiberglass reinforcing for the main application
    then the Bondo Filler for basic filler and smoothing
    then the Bondo Spot Putty for the pinholes
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
  8. #38
    Oct 2003
    Poland, OH
    brrman, does that "Bondo Spot Putty" just squeeze right out and ready to use? Or do you have to mix it?
    I used the "Body Filler" like in your second picture after I did the fiberglass resin. I had to mix that with hardener each time which sucked..
    So maybe the best idea is to use that tube that squeezes out and is ready to use and push it down into the holes with a razor blade??
  9. #39
    Newbie 350zMountaineer's Avatar
    Feb 2006
    NJ
    Quote Originally Posted by tbird2340
    Ok. I just got an extra Bezel and an empty Xenarc casing and I need some help.. The problem is that the Xenarc is a hair wider then the opening of my bezel. I had the Lilli which would have fit perfect but it SUCKED so I bought a Xenarc instead. Here are some pics:
    I am thinking of putting the LCD behind the Bezel and bondo'ing it.. I'm not sure if it will be TOO recessed though.. I'm hoping people have some opinions on what I can do..
    EDIT: I'm stupid and just realized that the buttons wouldn't be accessible.. Anywho.. Please help. If more pictures would be helpful let me know.
    Thanks!!
    Anyone seen a custom bezel for sale for the floor mounted console in a 99 Mercury Mountaineer?! Not that great with car repairs to even put me near bondo.
  10. #40
    Nov 2004
    nope
  1. So i got a 40x4 off ebay...
    By MikeHunt79 in forum LCD/Display
    Last Post: 03-04-2004, 03:00 PM
  2. Using Small LCD Monitors with Digital Camera
    By darethehair in forum LCD/Display
    Last Post: 11-02-2003, 07:47 PM
  3. Lilliput LCD monitors
    By 001 in forum LCD/Display
    Last Post: 10-27-2003, 03:46 PM
  4. Small but functional Char LCD
    By TheFly in forum LCD/Display
    Last Post: 04-23-2002, 04:26 PM
  5. Replies: 4
    Last Post: 03-16-2002, 02:32 AM
