Page 1 of 23 1234567891011 ... LastLast
Results 1 to 10 of 224
Thread: Build own clear led lights
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Ok so we have all seen the ones for sale etc
    Often sold as 'lexus style' on ebay.
    Anyone tried to make any for cars that you cant buy them for?
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    There is a site in Japanese that has pictures of one of those.
    They look great, IMO.
    http://members.jcom.home.ne.jp/altez...y-tail2-01.htm
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Very nicely done, but it seems he has used an opriginal clear light cluster and removed the original reflectors etc replaced them with a metal disk?
    My problem is I cant find a clear cluster/module call it what you want to build into.
    I have tried moulding a piece of clear perspex (plexiglass usa?) over one of my original light units to get the shape, but with the heat I also melted the original!
    (and never got the right shape...)
    The leds are fine though and bright enough, bought off ebay.
    UK readers beware to fit an led is illegal! it must be a 'type' approved led and have an 'E' mark on it, as its technically a bulb, and _all_ brake/running lights must be E stamped.
    (they also under old uk law have no spec for the amount of light emitted, only power consumed, so the brake light must consume 21watts of power, but be 0.1% to 100% efficient and still be legal)
    (oh hang on, the high level brake light in rear window as fitted from 80's etc is a light specified not a power specified light)
    Oh and red only to rear, white to front, flashing AMBER(not yellow or orange) for direction indication.
    Orange for marker lights on side of vehicle or beacon on roof.
    The only yellow bulb in uk law is the yellow flashing one on an airport baggage truck!
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    found these that show other goos examples..
    http://www.sca40.com/led/
    http://web.comhem.se/~u33113170/led/
    but both seem to use original fitment with new lights inside, I need to replace my original red/orange fitment with nice clear/chrome look...
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Oh eck found the ultimate DIY job.
    He has done what I may have to do, re-build the stock lights.
    I would love to know how he has got the red plastic out/off replaced etc but I cant read a word of it, but the pictures tell quite a story.
    http://ww6.enjoy.ne.jp/~vaf/car/led.html
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    Maybe the plastic was clear but the red was on the thing that holds the lights behind it? I gotta figure out how to remove the color from my taillights too =\
    CarPC install is starting to come along again...
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    If you look at pic 15(15.jpg) and zoom in a bit, it looks a bit blocky but you can see the new clear pieces have a white edge, like they have been cut from clear and stuc in/on. and you can count the 100 or so led's in that top half...
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Anyone thought about using Luxon?
    Jun 2004
    Seattle
    It's easy. If you have taillights that are made up of squares (or whatever shapes those may be) you should be able to cut out separate squares and replace them with transparent material (say, CD case plastic cut to fit) then use a soldering iron to "melt" it in place, use some sand paper to smooth out the surface and apply clearcoat - bam! you just made your tails transparent. Now you just need to put something nice and shiny inside
    I would do that, but I'm too cheap to buy myself a set of taillights and I don't want to mess with the original ones in case I do something wrong.
    PS: if you have "round" taillights like those on newer vehicles, you could probably get away with heating the cut-out CD casing to a point where it is soft and apply it like a film to the taillight so that it bends the right way. Once cold, it should be nice and solid. Make sure you use LEDs tho, or you're running a risk of melting your custom housing
    Then if your car is like mine, doesn't have any custom parts for it, you could sell this stuff for big bucks on eBay. I know a guy who paid over $1k on a set of Nissan Skyline headlights to do a conversion in his Saturn
    Jun 2004
    Seattle
    Plastic glass found at ACE Hardware bends very well after you put it in the conventional stove for a few minutes.
  1. Does anyone want to build a fiberglass mold?
    By SecretSpyder in forum Fabrication
    Last Post: 11-09-2007, 05:10 PM
  2. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  3. Clear plastic window for LED or IR Senesor
    By antimatter in forum General Hardware Discussion
    Last Post: 03-07-2005, 12:32 AM
  4. Illegal Lighting?
    By lgbr in forum Off Topic
    Last Post: 04-03-2004, 02:26 AM
  5. Changing keypad LED lights!
    By brandondere in forum General Hardware Discussion
    Last Post: 04-11-2001, 11:13 AM
