I have seen similar done with case modding, but in all cases, the cpu will be wet with the condensation that occurs. Not what I would consider a safe mod. Watercooling is already a bit extreme for carpc use.
Well, I just had my first major break down with the Shuttle. And it was ofcource a heat issue. The system restarted itself, then froze in dos, then when I went to shut it down, it died fully with the red extreamly bright CPU Overtemp Warning light on. Turned out the cpu hit like 80 degrees celcius. I guess thats not good. Well I know that the AC system uses freon, but there's ways to hack my system to use the new aged stuff that could make my ac freeze! I could only imagine how cold the fluids are that are being pumped into and out of the AC unit....so do you think I could tap into it and watercool my system with the AC Freon system?
1987 Pontiac Fiero GT
XPCarputer Coming Soon
[IIIIIII---] 70% Complete
XPC Model SN41G2V2
AMD AthlonXP 1800+
2× Mushkin 256MB DDR
Pioneer DVDRW
80GB 7200RPM UltraATA HD
Windows XP MC2005
XM Satellite Radio
•ñFïnïtε Τחטіתģ•
2005 Ford Focus ST
Peltiers - especially useful if you housed your computer in an amp enclosure.. you can just hook up the cold side to the CPU and the hot side to the amp enclosure. I did a science project about peltiers and they are great, if you have the right size.
Well if I did that, theywouldn't be be touching the enclosure....I'd have to get 2, one big one for the CPU and one smaller one for the chipset. Do they work if the hot side is in air? I am going to order some small fans to put in the back of the case blowing towards the cpu.
XPC Model SN41G2V2
AMD AthlonXP 1800+
Pioneer DVDRW
Windows XP MC2005
XM Satellite Radio
•ñFïnïtε Τחטіתģ•
Ok, I just looked up Peltiers on FrozenCPU.com. and it says you have to have something to cool the hot part of it, so it doesn't burn up the entire unit. And the best thing for my AMD Athlon Mobile 3500+ CPU requires 250w of power. The power supply is a 200W Power Supply. the stock SilentX power supply on the shuttle is a 250W....I dont think I'll get away with powering it.
I need to find a good, safe, way to cool my damn AMD!
XPC Model SN41G2V2
AMD AthlonXP 1800+
Pioneer DVDRW
Windows XP MC2005
XM Satellite Radio
•ñFïnïtε Τחטіתģ•
Where do you have your PC located? could you not build a long heat sink out of the side of the case and pass the aircon pipe through it a few times. This way the coldest part of the heatsink (most likely to get condensation) will be outside the case and if you put a temp sensor ont he heatsink inside the case which warns you if the temp gets near a condensation creating level (so you can wack on a bit of doom to get that cpu working hard!!!! (or turn the aircon off)
Your best bet is probably to use the tried-and-true methods of blowing lots of air across a big heatsink. Without having looked at a picture of the case, you might be able to put a fan in the case near the CPU, or clean up the wires in the case to facilitate better airflow.
It is true that peltier devices eat lots of power, but it's also possible to run them at fractions of their rated power most of the time and ramp the power when needed. I also think that they don't require tightly regulated power like the rest of the components in your computer, so you may be able to get away with a cheap separate power supply for it. You just need to be careful about how you do that to prevent it from stopping working at all.
Old plans out the window because of an accident .
Have: M1-ATX, EPIA M10000, 256MB, 60GB 2.5", slim slot load DVD
Need: Time, HU integration, ideas for Lilli
get a Zalman Flower - CNPS6000-Cu
I have one on my 1600+
CarPC status: iPod, 3,456,217 songs so **** you
So do I! The processors ALWAYS shows a few degrees cooler than ambient.Originally Posted by Motoko
My first attempt at a carputer.
PM me if you're interested in a monitor faceplate for your '99-'04 Golf or Jetta. My Vortex ID is NorthAtlR32 - you can IM me there, too. Go here for more information.
Also know, space is a issue...the cpu is like 2" below where the DVDRW is goin. Water cooling systems aren't harsh....and I could possibly get away with building a water cooling system externaly from the case without condensation.
Also the case is mounted in the glove compartment...the case is a 12 disc cd changer.
XPC Model SN41G2V2
AMD AthlonXP 1800+
Pioneer DVDRW
Windows XP MC2005
XM Satellite Radio
•ñFïnïtε Τחטіתģ•
