I'm trying to think of something cool and unique but can't! Why not put a few buttons there for quick access to GPS, rear view camera etc or maybe have a nice phone holder/charger there.
I have made a decision and have moved forward - see below for more pictures of fabrication.
The lower dash bezel of my truck has a little more room than most people have, so I am trying to decide what items I should fiberglass into it and where things should go.
Right now I know I will have a Xenarc 7" display, a slot load DVD and at least one 12v power outlet (removing two stock power outlets during install)
Here is the bezel with some life side cutouts
I was thinking a power switch so I could just keep the computer powered off for short trips and times I don't want the computer to power on just cause I have the key on.
So what else should I install?
I was thinking of putting like a 6 in 1 card reader next to the screen, but don't think it would look good and I would not use it enough since my case will be pretty easy to access under the rear seat. I thought about a griffin powermate knob, but decided that might be too large and bulky.
It does not even need to be carputer related.
FYI: stock setup looks like this - that lower section is getting replaced:
I am a newbie trying to outfit a couple cars with new custom consoles and mini ITX. Click here for my 2003 Chevy Avalanche project.
I'd fill it with a larger screen!
Fabricator
Here are my ideas: a small tray (looks like there's already one there), a media reader, a Character LCD (for when I don't want the main LCD on and to keep it clean when playing visualizations / movies - or for displaying random information like outside temperature or OBD-II stats), a few USB ports, maybe a firewire port, ethernet & 110v AC ports (i have lots of friends who bring their laptops along everywhere), DVD drive, or a docking space for a mini-keyboard.
Old plans out the window because of an accident .
Have: M1-ATX, EPIA M10000, 256MB, 60GB 2.5", slim slot load DVD
Need: Time, HU integration, ideas for Lilli
I was thinking some kind of phone holder would be good to have. How would those buttons work? Phigits? I want serial port for the vehicle data, so I guess it would have to be USB or something?Originally Posted by Scouse Monkey
Problem is most all the good skins and front ends are designed and ready to be used on the widscreen format like the lillis and xenarcs. I don't want to be one of the few guys trying to tweak the skins for an odd size screen others don't have.I'd fill it with a larger screen!
I have a 10.4" 4:3 touchscreen in my basement now which with a little tweaking would fit, but am not going to use it.
My suggestions:
Alright you got an Avalanche, you can't just have a 7" xenarc... especially when you have that HUGE portion of your dash that basically holds cd's and cigerrette ashes....
You gotta custom mold that 2nd part below the radio and heater controls with a 10" touch screen, you might need to mount your slimline DVD drive vertically to fit but that would be excellant ! If you still need those 12v for other electronic accessories then think about re-locating them to the sides of that consol (towards the driver or towards the passenger)
I'd lay this out for you using adobe... but I'm at work and dont have the time !
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
Some good ideas. Going to have to re-look at some display dimensions and see what might work. I am not good at programming, so I hope these new USB ones are easy to use. Don't need temp - that is in the mirror, but winamp stuff might be nice.Originally Posted by RPI Geek
I would prefer not to have raw USB and firewire holes, but if I could hide it behind a door or something, it might be nice. Maybe a hingle or slide up/over cover like from a desktop computer case. Have a few extra desktop cases around here someplace that need to meet MR Dremel tool.
I have 110v power built in. I did that right after I got the truck as I have a laptop with me all the time.![]()
It's located in the rear of the center console. There are A/V ports so people in the rear seat can plug in an Xbox or PS2 and use the LCDs in the truck to play games or watch a different movie there.
Frodo will resize the skin to 800x600 i think if you wanted to use an 8 inch screen. For buttons you can either just use a joystick connector or you can hack apart a game pad (as i am gonna do) and use somthing like girder to interface it with your frontend.Originally Posted by gadget
Serious - you don't think 10" LCD is not too large? Here is a picture with one of my extra 10.4" touchscreen tablet computers laying under the bezel so you can see the size. I could fit a slot load on it's side (is it OK to do that?) next to a 10" LCD I guess. It will be tight, and it will have to place the drive toward the bottom as I only have 3" behind the bezel up at the top but 10" deep down lower in the console.Originally Posted by IntellaWorks
I do have a couple other areas I could put things - the square hole next to the HVAC could be used. I have a factory faceplate for this and it could hold buttons, 12v outlets or other things if I need to. I planned to put 2 12v outlets in there and have the parts, just figured I would have room in the new bezel with a 7" screen.
Sod it - go witht he 10 inch screen. Can you post a pic of your screen placed in the hole where the lower bezel was (like the second pic)
