Results 1 to 10 of 11
Thread: Project lexus ES300 with 300 or so pics
    Newbie mlazzaro@excite's Avatar
    Sep 2002
    westwood nj
    I want to post my project for everyone to check out
    PROJECT ES300 WEBPAGE
    now I need some good navigation software to use with my gps. I need something that will talk and is easy to use with a touch screen. also is there any way to reduce the glare on the lilyput screen/
    Jul 2004
    Business Class
    These questions have been answered quite a few times. Good project car.
    PROJECT ST34LTH : A 100% integrated car computer with fulltime wireless internet and audiophile-grade sound and exquisite video in a Black on Black Mercedes-Benz S500
    _
    Mar 2004
    Little Elm, Texas
    looks like it took a lot of work....quite risky to do your dash with it still in the car though!
    glad to see it all done! thanks for posting the pics!
    same as ST34LTH said....there are specific forums dedicated to both of the questions that you asked.....a GPS forum and a LCD forum....do a bit of searching....
    welcome BTW!
    Jan Bennett
    Newbie mxl4729's Avatar
    Dec 2004
    westwood
    Quote Originally Posted by Red GTi VR6
    welcome BTW!
    yea but it is so much easer to ask then to but anyway the reason i did it in the car was becuase i needed dash as the mold i did not use any of the dash peaces around the screen over again
    _
    Mar 2004
    Little Elm, Texas
    so I'm guessing you are mlazzaro@excite too?
    *confused*
    Jan Bennett
    Constant Bitrate dingofarmer's Avatar
    Oct 2004
    colorado
    looks great
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    SCREW YOU!!!!!! I have a 98 ES300 and I thought I would be the first to have a carputer in our model year on this board!!!
    All I can say is GREAT JOB! I've only installed the head unit, amp, infinity basslink, distro block and speakers so far. I purchased one of those dash fit kits that finally came out for our cars and currently using that as a temporary solution for my aftermarket HU.
    The metal bracket for the stock radio and HVAC controls looks like it could hold 2 DIN units, so I am planning on installing my Xenarc into an in-dash unit. When that is done, I have to fabricate some sort of dash piece to accomodate the aftermarket HU and the in-dash monitor. I have a mid-tower ATX case waiting to be installed in the trunk.
    I really like what you did with the MDF pieces in the trunk. I've currently mounted my amp, inverter, power strip and distro block to a piece of carpeted plywood and when the carputer is in, I plan on mounting it against the rear seatback. The ATX case will go on one side of the trunk while the infinity basslink is on the other. To make it look real stealth, I may do what you did with your sub.
    I've run my power/audio cables the exact same way you did (power on driver's side and audio on passenger's side). One question though, were you able to fit all the cables under the plastic cover on the passenger's side of the car? We're talking about 3 AV interconnects, 4 sets of speaker wires, 1 vga cable, 1 audio cable from carputer to HU and a USB cable....??? Did all those fit under the plastic covers???
    One last thing, I was stupid and accidentally left my work light on the passenger's side plastic cover for about 5 minutes - it melted the plastic. It cost me $56 to get a new one from a stealership - so, just be cautious with any other work.
    Anyhow, congrats on your ride....I'm going to be hitting you up with a few more questions later on.
    -HD
    Nov 2004
    Where do most people keep their carputers? In the dash or in the trunk? Or somewhere else? :-P
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    Quote Originally Posted by BigfootsMonk
    some in the trunk...some under the driver's seat...others in the dash. wherever you have room for it
    rebuilding carpc... kinda..
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    great install! mounting the screen that far back help alot with glare?
    肚子笑痛了
    S60 Install
  1. Lexus IS300 install pics.
    By Fargo in forum Show off your project
    Last Post: 01-01-2008, 11:47 PM
  2. Lexus ES300 Carputer
    By amrit50 in forum Show off your project
    Last Post: 10-30-2005, 09:05 PM
  3. finally my project pics
    By osirisdon in forum Show off your project
    Last Post: 07-03-2005, 03:38 PM
  4. Pics of my screen-in-dash Accord project
    By mykolJay in forum Fabrication
    Last Post: 07-02-2004, 11:22 AM
  5. Hello!! CarPC project pics inside.
    By bobbykokinos in forum Newbie
    Last Post: 03-29-2004, 12:44 PM
