Page 12 of 13 FirstFirst ... 2345678910111213 LastLast
Results 111 to 120 of 130
Thread: How to: Duplicating a radio bezel.
  1. #111
    Dec 2004
    Quote Originally Posted by Giuliano
    Microballoons is basically a powder-like material that you can add to resin as a filler, to take up space and make the piece lighter. Think of them as microscopic glass balls or balloons, filling up space with mostly-air.
    wow, interesting stuff....can this be used in pretty much anything or only for molding?
  2. #112
    Variable Bitrate Saab9-5's Avatar
    Mar 2005
    Ponta Delgada, Azores
    I was also thinking of how to secure it.. magnetics would work, but I wouldn't want to put any magnets that close to the LCD, just because.
    What do you guys have against magnets? LCDs aren't affected by magentic fields the way CRTs are. And they wouldn't have to be that strong. Four small ones, one at each compass point, would hold a plastic cover perfectly in place. Not to mention the clean look since the magnets could be on the inside.
  3. #113
    Mar 2005
    BTW, great work on this writeup. Because of this, I've been able to mold smaller parts - replacement buttons mostly - but plan on doing bigger things. Thanks for sharing your work.
  4. #114
    Jan 2004
    So you can say with certainty that exposing an LCD screen to a magnet in close proximity won't have any adverse effects on it?
    I ask because I know a little bit of how CRTs work and why they are affected by a magnetic field disturbance, but I don't know how LCDs work.
    At least for me, it's just not wanting to take the risk at all because the LCD screen cost me so much to begin with.
    2002 Subaru WRX - Silver
    -FP18G turbo
    -Walbro fuel pump
    -Modified OEM 840 CC Injectors
    -TurboXS: UTEC, turboback, uppipe, intake
    -Blitz FMIC
    -STI cluster
    -17"x7.5" SSR Competitions
    -Tein Flex coilovers
    -NOS 50 shot
    -2004 rear conversion
  5. #115
    Mar 2005
    That is correct. Active-matrix LCDs depend on thin film transistors (TFT). Basically, TFTs are tiny switching transistors and capacitors. They are arranged in a matrix on a glass substrate. To address a particular pixel, the proper row is switched on, and then a charge is sent down the correct column. Since all of the other rows that the column intersects are turned off, only the capacitor at the designated pixel receives a charge. The capacitor is able to hold the charge until the next refresh cycle.
    You know that a CRT uses magnetic fields to aim the electron beam but LCDs just don't work that way. To even make sure I was right, I placed a magnet on top of an LCD of an old laptop and ran it for two days straight. No problems. As for the magnetic faceplate idea, I was only thinking of small magnets, no bigger than 1/2" in diameter.
  6. #116
    Variable Bitrate nzKAOSnz's Avatar
    Aug 2003
    Christchurch - New Zealand
    btw - old cdrom drives have excellent little magnets in them.... quite strong for their size
    92 Subaru Legacy Wagon
    Epia MII12000 :D
    Morex 80W
    120G External HDD
    16x2 Charater Display
    Creative IR Remote
    VIA Sereniti 2000 Mini ITX Case
    7.2Ah SLA Tank
    PCMCIA 802.11b
    256DDR Ram
    Diamonds are for girls- wise men follow the stars
  7. #117
    Jan 2004
    that info has given me a world of new ideas... sweeeet.
    -FP18G turbo
    -Walbro fuel pump
    -Blitz FMIC
    -STI cluster
    -NOS 50 shot
  8. #118
    Sep 2003
    Wilkes Barre, Pa
    Quote Originally Posted by imprezive one
    Just take a look at the new cell phones. They have both magenets and LCD screens with no problems..
  9. #119
    May 2005
    Are you going to use the Polytek 1510 for your final bezel ?
    I want to put my epia pc in a hidden compartment in the trunk of my 1'er.
    It is a really weird shape and want to pour a custom enclosure in that shape.
    Is the polytek stuff strong enough for such a build ?
    BTW: How's the bezel going ?
  10. #120
    Jun 2004
    hey wondering how the project is going and y u stopped posting hope u didnt run into any big problems would love to see your progress
    Starting an install in a 02 s4 when I get time, which will probably about the time i am looking to sell the car. Got to love it
  1. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 03:34 AM
  2. Replies: 35
    Last Post: 01-12-2005, 01:10 PM
  3. Custom Secondary input using old radio bezel?
    By anaxagoras in forum Input Devices
    Last Post: 11-03-2004, 09:54 PM
  4. Fm Radio
    By vicky_obee in forum Media Engine
    Last Post: 07-01-2004, 10:52 PM
  5. How do i make Radio working in MediaCar?
    By zvi in forum MediaCar
    Last Post: 05-16-2004, 02:38 PM
