Page 3 of 13 FirstFirst 123456789101112 ... LastLast
Results 21 to 30 of 130
Thread: How to: Duplicating a radio bezel.
  1. #21
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    I'm confused as to what the 'venting' and 'pouring' channels are. I guess you pour in the plastic in the pouring channels and then it exits the venting channels? or the air does? I'm not familiar with liquid plastic at all, but I'd like to know more about it. Also, where are these channels? I don't really see any special grooves for pouring into or anything. I guess I'm really missing something here.
    CarPC install is starting to come along again...
  2. #22
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    yeah you pour into the pouring channel, but the resin would not go into the mold unless the air could escape - so you have venting channels for the air. You keep the channels as small as possible to prevent the amount of clean up after the mold has cured.
    You put a small piece of material (mini straw/thick toothpicks, coat hanger, etc) to take up room when you make the mold. Then when the mold has cured, remove the toothpicks and you have an empty area that becomes the vent.
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
  3. #23
    May 2004
    Arkansas
    i see. where are the channels at? anyone have any good links i might could read to get myself more familiar with this stuff?
  4. #24
    Aug 2003
    edited my above post about the channels
    check this out
    http://www.alumilite.com/howto.cfm
    I have been fooling with molds the past couple weeks. very interesting and I love this thread.
  5. #25
    Feb 2004
    Quote Originally Posted by brrman
    Good answer!
    The channels themselves don't have to be tiny, but it's usually a good practice to make the channel contact points (ie, where the channels contact the piece) narrow so that there's less material to cut off - the plastic that cures in the channels is usually referred to as the "sprue".
    A channel width of 1/8" is usually sufficient, but for larger pieces it's not unusual to have a channel of 1/4" wide, which is what I'm going to be doing - it makes the pouring slightly easier.
    The resin pours into the mold through the channels, and balances itself out by gravity.
    For example, if you had a plastic tube shaped in a U, and poured water in, it would self-level at each end, which is why you need to have both the pouring and venting channels come out the "top" of the mold.
  6. #26
    Feb 2004
    Photoshopped Image of "Finished" Bezel
    Here's an obviously photoshopped image of what I expect the modified and finished bezel to look like.
    I'll probably end up painting it a pretty blue color to match the car..
    I've got some specialized hobby paints that will do the job nicely - they're acrylic lacquers, so they go on real smooth and are real durable.
  7. #27
    Feb 2004
    Quote Originally Posted by Giuliano
    On second thought...
    What better way to make it look "factory" than to paint it using factory paints?
    Subaru Touch Up paints, that is - they're about $5 for a 1 ounce bottle, and for my WRX, I believe the matching color is World Rally Blue.
    Now, you might think.. 1 ounce of paint is not enough!
    It is if you airbrush it! (which I can, I've got like, 3 of them)
    Combine the radio bezel with the center, left, and right A/C bezels, and you've got a paintjob on the inside that will look factory...
    Did I mention that if I spray the inside of the mold with primer, and let it dry before I pour the resin, the resin will bond with the primer? Instant pre-primed part, ready for painting.
  8. #28
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    A quick post to say how great this thread is and i look foward to the continuation
  9. #29
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    If you have an air compresser you can buy an airbrush kit for that dirt cheap from Harbor Freight tools, it should do the job.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
  10. #30
    Feb 2004
    Quote Originally Posted by Pudge
    If you meant me, I already have at least 2 airbrushes now, both meant for hobby-size work:
    The air compressor is pretty silent, and only runs when I press the airbrush trigger - I added a low-pressure regulator so I can dial down the pressure to 5-10 psi for detail painting.
  1. Class 2 Data Bus
    By owenjh in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-09-2008, 03:34 AM
  2. Replies: 35
    Last Post: 01-12-2005, 01:10 PM
  3. Custom Secondary input using old radio bezel?
    By anaxagoras in forum Input Devices
    Last Post: 11-03-2004, 09:54 PM
  4. Fm Radio
    By vicky_obee in forum Media Engine
    Last Post: 07-01-2004, 10:52 PM
  5. How do i make Radio working in MediaCar?
    By zvi in forum MediaCar
    Last Post: 05-16-2004, 02:38 PM
