Results 1 to 10 of 17
Thread: Peugeot 306 7.5in Widescreen install
    Jan 2005
    UK
    I originally had my Monitor, a 7.5" centurion widescreen mounted on top of the dash but i couldn't stand it there. I had a bit or fibreglassing experience so i wanted to make my own dash install. The original dash looks like this.. so you can see my problem.
    I had to rip out the top vents and the din-slot to get the dash anywhere near capable of holding the screen.
    After i'd done this i cut the shape out of some ply-wood and began fibreglassing the wood. I put about 3 layers of matt on just so it wouldnt snap when i prised it off, and it didn't. I cut the general shape and sanded the edges etc and cut a hole (square) in the middle for the screen.
    Then i measured some cardboard out for the back of the screen and made a box for the screen to sit in (sorry if this doesn't make sense it's hard to explain!) i fibreglassed the box to the back of the shape (behind the square) i had created for the dash and tested for a fit.
    The rest was filling, sanding and painting.
    I've noticed there are a few people with 306s on this forum, i'd really like to know how you did your screen
    Constant Bitrate Caitlin's Avatar
    Dec 2004
    Manchester
    Yeh, I got my 306 fascia half off tonight and realised that the heater controls arn't attached to it at all I think i'm going to have to go the same way as you have.... what have you done with the heater outlets? did you move them someplace, or are they happily keeping the back of the lcd hot?
    I'm going down to a breakers to look at complete fascias, it seems that the xlt or glx (can't remember off the top of my head) version has a 2 din size hole... but i'm not sure if you can switch them out easily :/
    Why the demise of the temp and clock controls?
    It's looking good, how do you find the angle of the screen in use?
    Getting my screen on weds... can't wait to furtle!
    Nice job though, well done.
    Cat
    Woot, or something.
    Epia M10000 (less rubbish than the 800) :: LCD touchscreen
    GPS :: 80G drive :: Not enough ram... Never enough..
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    sheesh you moved your steering wheel to the other side of the car just to mount a screen?
    looks great!
    肚子笑痛了
    S60 Install
    Jan 2005
    UK
    Caitlin -- I didn't originly have temp and a clock, the pic above is from google.
    everything's the same minus the heating vents and the DIN.
    The angle is great! it doesn't reflect nasty light and glare in the day.
    Good luck with your project, let me know how it goes!
    jcdillin - i *knew* someone would say that haha
    Dec 2004
    Manchester
    's ok, I nipped round and fixed it with some mdf and sticky back plastic.
    looks great now....
    ..had to do the old time travelling crap to fix the *before* of course
    Where's the head unit now though? or is it going straight to amps?
    Cat
    Woot, or something.
    Newbie SpacemanSpiff's Avatar
    Jan 2005
    London
    If you want to keep the headunit, I mounted the screen down where the ashtray is, not ideal, but I've taken it all out as I'm getting a Golf Mark V, probably going to be even harder to get everything in.....
    alanp - Am interested as to what exactly did you do with the heating vents? Did you vow never to use the heater again incase it superheats the screen!!
    Jan 2005
    UK
    Nice Caitlin
    Na I dont use a headunit anymore. I was going to but i soldered it and.. well.. err u can guess the rest
    I fibreglassed up the heating duct so all heat coming from the engine is diverted to the two side vents or the windscreen or whatever. It's better because i can melt windscreen ice quicker as more air is directed to the windscreen. it's just like having the two old center vents off.
    Mounting it below the ashtray sounds like a gd idea. Got any pics? What's the angle like to view?
    Raw Wave
    Jun 2004
    On the beach
    Hey guys,
    In the process of fitting my 7" TFT in my Pug 306. Goign the same route - ripping the vents and headunit out but will be using the existing fascia unit as want to integrate the screen into the dash itself. Will post pics once done - went to the scrapyards the other day to rip a dash apart on a Pug 306 so I knew exactly what I was doing before I messed with mine!!!
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Hi alan, jsut chating to you over on the other thread. I am planning on keeping my vents which is gonna be a mission and i planning on keeping a HU in the dash and fitting a slot DVd so its gonna be tight!
    edit: oh and i have AC so i have an extra couple of buttons under the heater controls! very tight indeed!
    Jan 2005
    UK
    Quote Originally Posted by Scouse Monkey
    Yeah definitly tight! are you sure there's room for all of that! i looked at moving the heating controls down a bit but i think there's only 1 other thread that discusses this and it's not even peugeot specific, let alone 306 specific!
    I would have liked to keep my headunit too but to be honest, i just wanted it all in quickly and the epia soundcard does the job.
    Nice to see another 306 owner with plans for an install
    306 CarPC
    • Fibreglassed lcd installed into dash
    • Griffin PowerMate
    • epia 800 512mb sdram
    • MediaEngine
    • MapMonkey
  1. Peugeot 306 TD-OBD?
    By sygad in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-31-2009, 12:04 PM
  2. cloudy's 406 install
    By Jamez_Warner in forum Show off your project
    Last Post: 11-18-2005, 01:53 PM
  3. Peugeot 605 TD Carputer install 8"TSK/GPS/DVD...
    By sixofive in forum Show off your project
    Last Post: 02-02-2005, 02:40 PM
  4. Peugeot 206 2.0 HDI Install. (56K watch out)
    By cbyriel in forum Show off your project
    Last Post: 11-11-2004, 08:21 AM
  5. Peugeot 205 install with a portrait LCD (finally)
    By MikeHunt79 in forum Show off your project
    Last Post: 04-29-2004, 08:02 PM
