Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
Thread: Project: Toyota Matrix indash LCD begin (56K beware).
  1. #21
    Jul 2004
    Awesome fabrication, two question though.
    1. Did you only use bumper repair?
    2. What sanding process did you use?
  2. #22
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    1) I use Epoxy to glue the Screen frame to the dash bezel. Balsa wood also added to create larger bonding surface. Filling the gap with the Bumper repair only. Bondo brand Glaze and Putty to fill pin hole.
    2) I pre-sand ALL bezel and Lilliput frame with 100 grid. After SEM stuff dry, sanded with 100 then 150, then 230. Then on to 2nd fill, then sand with 150, 230, 400. The last sanding is with 400 wet sand. Prime, then wetsand with 400 and 600 for couple times. Also I did fill those pin hole during the prime/wetsand stage.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  3. #23
    Jul 2004
    thanks MatrixPC
  4. #24
    Sep 2003
    Beach City, Socal
    The final In-Dash fab process with the radio installed. Click on the picture to enlarge
    Another
    Since the Alpine Radio took place of the 115V outlet and socket. The outlet and socket must go some where. Well relocate below the shifter
    That's it. The next process is redo the Mobo Case and all the wires.
  5. #25
    Constant Bitrate slangnasty's Avatar
    May 2004
    San Diego
    I really like the work you did on the plug-in. That looks great!
    - CarPC install complete.
    - CarPC software: CENTRAFUSE
    - Planning/working on in-dash for lilliput monitor
  6. #26
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    wow, great job, makes me want to pull mine out and do it again!
    肚子笑痛了
    S60 Install
  7. #27
    Nov 2004
    ahh skeet skeet skeet skeet!!!!
    That looks great. Did you put it up on matrixowners.com yet?
    It's been too cold to bondo here so mine is still unfinished
  8. #28
    Newbie The Vic's Avatar
    Jan 2005
    Macon, GA
    how do u access your options in which the buttons on the lilliput case were??
    Its like my pool's tearing *** around the back yard, but its not really moving...
  9. #29
    Sep 2003
    Beach City, Socal
    Look like the bandwidth for those pix are over the limit from photobucket. Anyway, next month.
    arise360 not yet, but will be soon when I re-organized all the wires.
    The Vic The Lilliput buttons are still there. In case you didn't see the pics. I just put the Lilliput case to the radio bezel without cutting any major part of the Lilliput. The radio bezel, well, I chop the bottom because the Lilliput is taller than the radio openning.
  10. #30
    Nov 2004
    Amazing work.
  1. 1999 Honda Prelude Indash (56k Beware)
    By SuperDave01 in forum Fabrication
    Last Post: 12-04-2007, 12:59 AM
  2. Toyota Celica 2000-> GT/GTS and LCD
    By Goose in forum LCD/Display
    Last Post: 12-24-2005, 11:34 AM
  3. WTB: Indash Project Housing (7" LCD)
    By Ninja Monkey in forum Classified Archive
    Last Post: 12-21-2004, 08:49 PM
  4. Replies: 5
    Last Post: 06-14-2004, 10:26 PM
