Page 1 of 5 12345 LastLast
Results 1 to 10 of 45
Thread: Project: Toyota Matrix indash LCD begin (56K beware).
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Project: Toyota Matrix indash LCD process (56K no go).
    Many of you guys inspire me to "indash" my Matrix setup. I have everything up and running with the Lilliput attached infront of the radio. Now it time to make it look GOODDDD.
    Original dash look.
    The Lilliput in infront of the radio
    This is where a Single DIN Alpine CDA-9830 HU going to be install. The Aux/cig power outlet will be remove. The 115V switch and plug will be relocate to somewhere I havn't figure out get.
    Closeup for the Lilliput
    Flip down the Lilliput. The radio has been modded for aux audio input by spliting the CD audio.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Sep 2003
    Beach City, Socal
    Radio bezel removed
    I bought a use radio bezel from another matrix owner for 20 buck with some scratch. That doesn't matter cuz I will sand and bondo over it.
    This is the back of the bezel. There are some switches (AC, Hazard, Recir, ..) attached to those holes.
    Lilliput case I bought from Armen a while a go for 15 bucks. The Lilliput is a little taller than the double DIN opening of the bezel but narrower.
    This saw did the job of cutting the bottom part of the bezel out.
    Wet sand the silver paint out.
    Now I need to glue the 2 togethers. The bezel is made of ABS plastic. What type of adhensive should I use? I know I have to do some searching and reading on this forum to see what you guys use to glue the 2 together.
    I currently have Bondo and Bondo Glass, Can I use it that or it will crack on me? This set up have to be perfect that is why I ask. I saw others using the more flexible stuff for bumber repair. I may look into that material.
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    Where did you get that clip for the lilliput? I need something EXACTLY like that for my Xenarc install.
    Can you give me more details about the hinge, the hardware, is it sturdy enough to survive bumps in the road, etc. Thanks!
    -HD
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by hd54321
    -HD
    You can get all from HomeDepot. The hinge is a 3" or 2.5" door hinge. The "clip" is a piece of metal (wood join???) from HomeDepot and I just bent it to the curve of the Lilliput. Velco to the top of the radio. I have no problem goign over speed bumps and pothole.
    Jun 2004
    Los Angeles
    Quote Originally Posted by MatrixPC
    Brilliant!!! I've gotta check this out now...I need something EXACTLY like this. Thanks.
    -HD
    Sep 2003
    Beach City, Socal
    What type of plastic is this Lilliput case? I can't find any stamp/reading on the case.
    Will this adhensive SUPER GLUE ARALDITE 90 Second Super Instant Epoxy by Pacer Technology
    bond the Lilliput case and my bezel (PC+ABS) plastic together??
    Maximum Bitrate VanMan69's Avatar
    May 2004
    Alameda, CA
    I think that stuff will bond an elephant to an airborne 747 (even an elephant laminated with ABS). You should be okay.
    95 Chevy G20 Vroom Boom Room
    ...with a whole bunch of nifty ****... go check it out: VanDomain Page
    Sep 2003
    Beach City, Socal
    Well, I did a little bit of work yesterday.... Sand the bezel and the Lilliput case a little bit and glue/epoxy them together. The bezel is a little wider than the Lilliput case so I have to use some balsa wood to fill the gap.
    Back with epxy fill in
    Front.
    Waiting for the thing to cure. Any comment and suggestion is welcome.
    BTW, I will be using SEM: Bumper Repair #68422
    to fill and sand instead of bondo/bondo glass. Maybe bondoglass in the back to add some strength.
    Sep 2003
    Beach City, Socal
    Test fit: Now you guys can see where my Earthmate GPS is. That little yellow thing deep inside the dash.
    SEM bumper repair apply and wait for sanding.
    Oct 2004
    for future reference check out duramix, they make a range of ABS plastic fillers and putties, its a bit more expensive that the epoxy's but it sticks to anything, sands really whell and looks amazing, its like liquid plastic and it sets in 15 minutes.
    Cheers,
    Grant
    '03 Corvette Z06 - car pc soon
    '99 Eclipse GSX
    '03 Ducati Monster
  1. 1999 Honda Prelude Indash (56k Beware)
    By SuperDave01 in forum Fabrication
    Last Post: 12-04-2007, 12:59 AM
  2. Toyota Celica 2000-> GT/GTS and LCD
    By Goose in forum LCD/Display
    Last Post: 12-24-2005, 11:34 AM
  3. WTB: Indash Project Housing (7" LCD)
    By Ninja Monkey in forum Classified Archive
    Last Post: 12-21-2004, 08:49 PM
  4. Replies: 5
    Last Post: 06-14-2004, 10:26 PM
