Results 1 to 8 of 8
Thread: A complete plexi glass
    Newbie rvk2's Avatar
    Nov 2004
    Hey guys, I'm planning on building an all-plexi case for my carputer project.....I have never worked with plexiglass, so I will be playing around with it before I start my final design. I've heard stuff like if I don't drill correctly, the plexi will melt. A friend of mine brought up an interesting question.....on extremely hot days in the summer, if the case is sitting in the trunk, would it melt?
    Considering the heat of the trunk, and the heat given off by the components, is it a good idea to go with an all-plexi case? or should I go with aluminum? I don't know what the temperature durability of plexi is, so I'm not sure if this is a good idea.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    check out to see how those modders have dealt with drilling, cutting, and polishing plexi. One thing to consider is the static properties of plexi. If you check out you can get static resistant plexi.
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Plexi will be fine. If you dont drill it right it will melt but only in the immediate vicinity of the hole. It wont ruin your project or anything. To minimize the gluing of joints, what I would do is bend as many corners as you can. This can be done with a propane torch from Home Depot or wherever. Dont put the flame directly on the plexi or it will bubble. Just hold it a few inches from it. If it starts to smoke,discolor, or bubble move the flame farther out. Run it back and forth along the area that you want to bend and soon it will become plyable. Then bend it around something to get a constant radius. I didnt do that part- just held it so that gravity pulled it down and bent it. Hold it at 90 degrees long enough for it to become hard again. It will be stronger than gluing it. Heres a link to the solvent and they also sell sheet in clear or colors.
    acrylic stuff
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    8" Lilliput touch screen
    dual optimas
    battery isolator
    15" screen
    My Truck
    Jun 2004
    bending plexi..
    the plexi i purchased at home depot had a protective cover on it.. when i heated it with a heat gun to bend it, the protective coating was very difficult to get off.. i'd suggest taking the covering off before heating.. i simply held the heat gun about 3 inches away from the plexi and bent it using a piece of metal piping.. came out real nice.
    Variable Bitrate nzKAOSnz's Avatar
    Aug 2003
    Christchurch - New Zealand
    How worried bout static should we be? Im wondering whether that was what killed my pc :S
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Keep in mind ther thermal properties of plexi. It will hold in heat like it's its job. Make sure you have plenty of case fans to keep it cool.
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Dec 2003
    ive seen someone use an alcohol solution to bend n cut plexi. of course you will have to ignite it to get the heat. i think as long as everything is grounded it should be protected from static.
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    I've always found it difficult to get strong, perfect corners with plexi. So, I took the easy way out and used L-shaped aluminum pieces and pop-riveted the whole thing together. I used a spare motherboard to get proper dimensions.
    I know you're shooting for a complely plexi design, but if you have a jigsaw, this is a less complicated and faster approach...
    2001 Jeep Cherokee
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
  1. Where to buy plexi?
    By futuresweets10 in forum Fabrication
    Last Post: 11-09-2004, 11:28 PM
  2. FS: Complete Mini-ITX CarPC w/Xenarc Monitor + More
    By DLe in forum Classified Archive
    Last Post: 10-19-2004, 09:15 PM
  3. Where to buy plexi glass from?
    By LekanB in forum General Hardware Discussion
    Last Post: 09-16-2004, 11:21 AM
  4. What to use to "glue" plexi glass or acrylic?
    By riddle14 in forum Fabrication
    Last Post: 04-19-2004, 01:01 PM
  5. Making new case lid out of plexi....
    By THEMP3KID in forum General Hardware Discussion
    Last Post: 04-22-2002, 12:25 PM
