Page 5 of 5 FirstFirst 12345
Results 41 to 42 of 42
Thread: How to cut need holes in metal?
  1. #41
    Oct 2002
    A nibbler is a good tool for case material. Dremel is fine too.
    Most electricians 'round here call the punches Greenlee after the mfg.
    Most industrial/commercial electricians would have them to punch conduit holes in service panels. ( you don't always have the right sized knockout in the right spot)
    Some posts seem to be referring to router bits with bearing guides- exercise caution
    as a router bit for ferrous metal is rare.
  2. #42
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    The air-powered nibbler is available from Harbor Freight (www.harborfreight.com) for $30 to $50. It uses a 3/16" nibbling bit, and you'll need a 9/16" hole to start. Just nibble close to the line you want, and Dremel or file the last little bit away.
    You'll need hearing protection -- the nibbler is loud.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  1. How to cut straight lines in metal?
    By Arathranar in forum Fabrication
    Last Post: 10-07-2004, 11:55 PM
  2. Single DIN mounting holes
    By god_of_cpu in forum Fabrication
    Last Post: 09-21-2004, 01:29 PM
  3. Replies: 13
    Last Post: 05-13-2004, 05:30 PM
  4. Do we need a metal PC case or is plastic OK?
    By -al- in forum General Hardware Discussion
    Last Post: 09-17-2003, 10:27 AM
  5. cutting holes in plexiglass
    By moahdib in forum General Hardware Discussion
    Last Post: 09-25-2001, 08:15 AM
