Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Fabrication Gurus: Here is what I want to try and do..
  1. #21
  2. #22
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Quote Originally Posted by kingtut
    Altimat: Are Microballoons the same thing as Microspheres? I have a friend of mine that works for a bodyshop, he has those cans of Microspheres but he does not know about Microballoons, he could not help answer the question.
    While we are at it, you mentioned that Bondo is not that good of a brand, is there any thing you recommend? My bodyshop friend get way too protective when I ask those questions, and no, I did not see any Bondo in his shop either. Thanks
    Yup same thing. And Bondo brand is the worst filler you can buy.
    Fabricator
  3. #23
    Frisco, Texas
    Tried RC store, he carried Microballons, but was out of stock. Finally found Cab-o-Sil locally. About 5 miles out of town there was a place that repairs boats. An actual "Garage" (so to speak), not a supply store. They filled a coffee can up with Cab-o-Sil for 5 bucks...
    Altimat... Say I have a Cup of resin/hardener. about what ratio of Cab-o-Sil do I want to use. Im looking for a peanut butter or slightly thicker
  4. #24
    Oct 2003
    WI
    I just add the stuff until its about the thickness I want. Add the hardener after mixing in the cab-o-sil or you may run out of time depending on the cure time of what you're adding it to. Don't make it any thicker than you need it to be.
    Fabricator
  5. #25
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    hey if u guys are interested i can do some stuff like that for you and send it back to u primed and ready to paint :-D
  6. #26
    Frisco, Texas
    For those that wanted some pictures:
    My progress. Whata you think?
  7. #27
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    The progress is looking good. You gen 7 guys have it so easy
    Just kidding. Good to see it going to plan without too much cutting up of the outer surround.
    4x4 in a turbo stylee.
  8. #28
    Newbie scaccess's Avatar
    Jan 2005
    Hamphire, UK
    Question Easier way?
    Why don't you use a sprung loaded pivot on the base of the screen with a small arm on the lid so that when you open the hatch the screen rises up a la james bond! Then when you close it it lies back down again. No cutting of the screen casing and no voiding of the warranty. Might well work for you.
  9. #29
    Frisco, Texas
    Quote Originally Posted by scaccess
    Original plan didn't look good. There may have been barely enough room to fit the LCD module (takin out of casing) inside the hatch, but it was too close to call. And that would leave no room for making its fitment inside the hatch look attractive... So I ditched the idea and cut the hatch out. I may revisit the hatch idea at a later time.
