Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Dodge Ram PC build
    Constant Bitrate strohmrs's Avatar
    Jun 2004
    Idaho
    Dodge Ram PC build
    Hello everyone. I got tired of having to install and remove my laptop in the truck and also having the exposed wiring so I decided to build a dedicated PC that will be hidden a little better. The PC is pretty much ready to be installed but I still have more details to work out such as getting a shutdown controller for the inverter and a more permanent dash install of the DVD drive and monitor.
    Here's what I've got so far:
    Center console ready to be reinstalled. Keyboard will be mounted on the sunvisor and the monitor in front of the dash.
    Lower storage compartment makes a nice home. Cable access is from behind the flipped up seat.
    The large switch is for the power selection mode. Red button is reset and the blue LEDs are for power and HDD.
    Bottom view of console. Best layout I could come up with for such a tight fit!
    Rear base of console showing two 80mm temp controlled fans.
    Front of console showing two 60mm filters for air inlet. May add a third if necessary to match rear airflow.
    This is the computer stack. It just drops in and pulls out when the cables are disconnected.
    This is the lower storage compartment in the center console with the computer stack removed. The stack sits on the lip halfway down that surrounds the front and sides of the compartment.
    Here is the computer stack out of the console. The MB is mounted upside down to the top sheet of plexi. 2" spacers then extend down to the lower plexi which has cut outs for the P/S fan and the CPU fan/heatsink. The P/S and HDD are mounted to the bottom of the lower plexi.
    Rick S.
    XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
    Constant Bitrate BeaverWise's Avatar
    Oct 2004
    Germany
    Nice install!! Are you going to be using a USB adapter for your dash mounted CD\DVD drive?
    VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
    Jun 2004
    Idaho
    Part 2 (more pics)
    Front of computer stack showing Ram and IDE ports.
    Passenger side of computer stack showing CPU heatsink/fan.
    Drivers side of computer stack showing Wi-Fi card.
    Rear of computer stack showing MB ports and suspended HD.
    Bottom of computer stack.
    Closeup of low profile Wi-Fi card. Just the right fit!
    Another view of the bottom of the computer stack.
    Rick S.
    Jun 2004
    Idaho
    Yeah. I have a USB/IDE cable for the final install. I'll have to extend the molex power cable a few feet as well.
    Rick S.
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Awesome work!!!
    Fabricator
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Altimat
    Awesome work!!!
    i agree...and that is a great compliment coming from altimat!
    Low Bitrate Bigassbike's Avatar
    Oct 2004
    On the computer
    Great to see another Ram!
    Planar 12.1TS
    Xenarc 700TS
    Xenarc MP-SC8 Mini P4 Aluminum Car PC
    Sound Blaster® Audigy® 2 NX
    2.8 Celeron D
    512 PC2700
    Dual Odyssey 1200s for Power
    Jun 2004
    Idaho
    Thanks for the compliments. Altimat, I hope my LCD/DVD install turns out even close to yours! I just need to get over the fear of hacking up my new dash I guess.
    Rick S.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    nice!! I love it! that is the perfect wireless card it being so low profile.
    肚子笑痛了
    S60 Install
    Jun 2004
    Idaho
    Yeah. I just happened to see the picture of the card on the box at Wal-Mart and wondered if it would fit. I went home and researched it a bit, took some measurements and got it. There was about an 1/8" left above the card, just enough for a small strip of foam to keep it from vibrating out of the slot. My original plan was to use a PCI riser and an existing PCMCIA/PCI adapter and card from my laptop. The low profile card worked out much better.
    Rick S.
  1. 2003 Dodge Ram 4x4 Laramie
    By GinoRP in forum Show off your project
    Last Post: 05-21-2008, 12:10 AM
  2. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 05:27 PM
  3. 1996 Dodge ram 1500 EXTended
    By chuckctv in forum Show off your project
    Last Post: 10-03-2004, 09:08 PM
  4. Dodge Neon R/T 1998 CAR PC
    By CDesigns in forum Show off your project
    Last Post: 05-07-2004, 11:01 AM
