Should be fine. Make sure you have ventilation though for the heat. Static shouldn't be a problem as long as each circuit is properly grounded which should be done anyway if mounting it in a wood box instead of a metal chassis.
check this out for me:
LINKY
this guy made a custom box and i'm going that route
could i mount a PC in this box?
do i have to be concerned with static or fire?
i can make it slightly bigger to fit a microatx case (thats my board)
[4Runna]
next - wifi
Rick S.
XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
each circuit? sorry i'm like slow with this stuff!
[4Runna]
next - wifi
Make sure your motherboard and power supply are properly grounded. There is too much electrical interference having a computer in a vehicle as it is. If everything is grounded to the chassis of the vehicle, that will reduce the chance of noise in your audio system.
Rick S.
