Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Lexan & MEK?
    Mar 2004
    Lexan & MEK?
    Ok, after reading hundreds of posts on how to "glue" lexan together, I went and bought some MEK. Well, I would like to know how exactly it works, i.e. what the heck is capilary mean and do? Oh also, where can I get an eye droper or deploying mechanism for the MEK? Any other tips related to this.
    Mar 2004
    Well, since i got ZERO damn replies, I ended up uses Plumbers Goop. Works awesome, just messy without proper tools
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Hey, i got a reply for you.
    I don't know much about working with lexan but i have experience working with acrylic.
    Capliary action:
    If you put some cloth in some water it will "soak" and the water will move up out of the container. This is capilary action
    You don't want an eye dropper you want a squeeze bottle with a needle tip.
    Go to any plastic supplier (we have Tap Plastics here in california) and talk to them. They will know exactly what you need. When working with acrylic I bought a samm can of "Weld On #14" (i think it was #14...the number just relates how viscous it is) I also bought one of the sqeeze bottles i mentioned along with the plastic. You will also need some guides that are at 90 angles to hold up the peice while your working. This is important for straight corners.
    Usually there is some sort of paper backing on the acrylic. Only peel back about an inch from where you are going to join the two peices. Then apply some of the solvent into the cracks. You only need a little bit of the Weld On and you will be able see the two joining. Do the same to the other edge
    I would suggest practiceing on a few small peices until you get the hang of it.
    Mar 2004
    Kewl thanks. I will keep that tip handy for my next case and try that. I definately will be planning more next time
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by Coeus
    Good grief - you really are shirty aren't you???
    I can't believe you don't know what capillary action is. Did you even try a dictionary or google and as for the eye dropper...what do you use eye droppers for?...Eye drops...Where do you get eye drops?...a pharmacy!
    No one probably answered at 1st as they thought you can easily find this out by yourself.
    Now for my contribution, the squeezy bottle that antimatter mentions might deliver too much for your needs (depending on your needs - as it may be perfect). I am imagining the type of bottle you use for acetone when doing electronics and if you have a pretty low viscosity (runny) liquid and only need small amounts an eye dropper may give you better control but will be tedious for large pieces and you may ruin your work taking too long.
    Oh yeah capillary action is also the drawing of a fluid up a narrow passage due to surface tension and adhesion. It is how trees and plants take water up from there roots (when was the last time you saw a tree with a pump to get the water up to the top?).
    Mar 2004
    You just following me around to raz me or what?
    I am just trying to spark some interest in my topics, since they don't appear to be very interesting.
    btw, thanks for the inputs.
    Not sure I have ever seen a tree with a pump on it. I will definately try this next case I build.
    Mar 2004
    Bristol
    hehe yeah i am! stop being so shirty!!!!
    Yeah trees don't come with pumps as there is nowhere to plug em in.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I did 2 acrylic cases, the first one with MEK and the 2nd one with Weld-On #4. Both came out very good, but the one with Weld-on look better. It is because I has a little more experience with the 2nd one. The result is less messsssssy.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Mar 2004
    Quote Originally Posted by Scouse Monkey
    You cannot plug them in? no way..
    Mar 2004
    Quote Originally Posted by MatrixPC
    Might be worth playing around with... Might redo my home PC, but need to come up with a better idea.
  1. lexan bonding
    By mp3z24 in forum General Hardware Discussion
    Last Post: 10-31-2008, 11:41 AM
  2. FS / Carputer in lexan custom case.
    By NDelMoore in forum Classified Archive
    Last Post: 11-29-2004, 12:49 AM
  3. fiberglass an lexan
    By djXternal in forum Fabrication
    Last Post: 09-28-2004, 08:43 PM
  4. FS: all kinds of stuff!
    By iamwiz82 in forum Classified Archive
    Last Post: 05-06-2002, 06:28 PM
  5. My Custom Lexan Case
    By dekodan in forum General Hardware Discussion
    Last Post: 09-27-2001, 07:43 PM
