Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
Thread: Bending aluminum into a case.
  1. #31
    Feb 2004
    Well, I made the first two major bends, and it looks like it's a success..
    Though the bending machine I got has a little difficulty with this thickness of material, it got the job done.. though it actually did bend the handles a bit.
    The two sides are uneven in height, but that's okay - I'll probably cut them to height with my dremel and a cutoff disk.
    The middle shelf / top will probably be joined to the case with some simple L-brackets and threaded holes.
  2. #32
    Dec 2003
    looking good. where did u find that mobo template?
  3. #33
    Feb 2004
    Quote Originally Posted by Tred
    It's a CAD drawing of the silkscreen top of the motherboard.
    I printed it out to scale, so it's a pretty good representation of the real thing.
  4. #34
    Dec 2003
    hows the rest of the case coming along?
  5. #35
    Feb 2004
    On hold right at the moment, I've been working on wiring my LCD panel, and that's taking some time.
    For the case, I need to find the right size standoffs to mount the motherboard, and that's been taking me a little while too.
  6. #36
    Constant Bitrate mikevsgeek's Avatar
    Jul 2004
    Auburn Maine
    Quote Originally Posted by Giuliano
    you can always get some spacers that screw in from the bottom and then use them just like standoffs for your motherboard.. thats what I did... I believe I ordered them from Jameco.com and as I recall, they had a bunch of different lengths
  7. #37
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    I like your case. Nice and compact. Check mine out.
    Custom case
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  1. External USB Aluminum case for laptop hard drives
    By jarubio in forum General Hardware Discussion
    Last Post: 04-19-2005, 07:24 AM
  2. FS/T: Dell Axim x5 w/wifi card and aluminum case
    By wizardPC in forum Classified Archive
    Last Post: 02-18-2005, 01:37 PM
  3. FS: sv24 / sv25 aluminum case w/ powersupply
    By e36mp3 in forum Classified Archive
    Last Post: 12-03-2003, 09:34 AM
  4. FS: shuttle fv24 / fv25 aluminum case w/ power supply
    Last Post: 11-11-2003, 09:52 PM
  5. Need your input on custom case
    By Adam F in forum General Hardware Discussion
    Last Post: 09-24-2002, 09:42 PM
