Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Where to find Brushed aluminum?
    Oct 2004
    Hey guys, I wanna put some brushed aluminum around my dash and Xenarc, where can I find some of this material? Thanks.
    Constant Bitrate Phythorian's Avatar
    Dec 2004
    Netherlands
    I'm working for an interior design company. We use Formica brushed aluminium, this as a laminate with real aluminium on top which you can get in several designs.
    It's easy to work with and looks great. Maybe check some local interior company's, maybe they have some leftovers!
    http://www.formica.com/colorchipdetails.jsp?chip_id=682
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I've got an 8" brushed aluminum Xenarc bezel I'll sell.
    Want to:
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    aluminium + wet and dry and a bit of elbow grease or a power tool with the right attachment
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    WilsonArt makes it too check their website.
    Fabricator
    Oct 2004
    Thanks Altimat I just ordered some samples from them.
    Jan 2005
    Or, if ya just want brushed aluminum...... Get aluminum, sheet aluminum, whatever thickness you need. Then, for the grain you want, experiment with different sandpaper grits. Get a big flat sanding block <i use either one of those black rubber ones, about 3x5 inches, or I just use my speedboard>. Personally, I generally like my aluminum grain between 400 and 800 grit sandpaper. Just make long, straight strokes across the entire piece. I hold the board wide, so you cover the most width with every stroke. Then just be sure to start all the way at one end, and make one smooth stroke all the way to the other. Smooth, straight strokes and you'll get a smooth, straight grain.
    I wish I had a better picture on here, but this was my favorite brushed aluminum project ever..... I fabricated the all-aluminum center console, the instrument cluster, and the door panel inserts for this 73 camaro. The console turned out great, welded it up out of 1/4" Aluminum, then rounded all the edges and brushed it with 400 grit.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    that looks amazing
    who the heck made that car? That dash is the same kind as mine. I must know.
    Maximum Bitrate Meatballman's Avatar
    Jul 1999
    Hartsville, SC
    Chevrolet
  1. where can I find low profile sound card?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 11-04-2006, 01:05 PM
  2. VB help needed - DVDplayer- Brushed metal
    By Custommx3 in forum MediaCar
    Last Post: 06-11-2004, 01:03 AM
  3. Where to find "classic" styled buttons?
    By rhurley in forum General Hardware Discussion
    Last Post: 05-23-2004, 11:15 PM
  4. need to find an adaptor for the 12vDC on the back of the lilliput screen
    By DSM97RS in forum General Hardware Discussion
    Last Post: 04-17-2004, 05:21 PM
  5. Replies: 5
    Last Post: 07-12-2003, 01:43 AM
