Results 1 to 5 of 5
Thread: Too cold?
    Frisco, Texas
    Too cold?
    I went for my second round of laying fiberglass tonight. I'm using Epoxy Resin. Unfortunately, when I went to mix A Resin and B hardner. The resin was alot thicker than it had been last night. Was way too thick to be workable. weather.com has us at about 42-45 degree tonight (It was like 60 something last night)
    Is it just too cold for the resin to be workable? or did i screw up, like not screwing the cap on good enough (will epoxy resin harden without being mixed with hardener?)
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Yeah the temp is too cold do any kind of fiberglassing. If you look at the directions it usuallys tells you the temps that you can work with, most likly it will say to use it when the temp is above 60.
    Btw: your lucky you can work on your car in the winter. I haven't been able to do anything for over 2 months now. Tonights low is around 4 degrees.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Frisco, Texas
    Didn't know it would be unworkable... I just figured it would take longer to cure.
    Yea... 4 is damn cold. Only bad thing around here is that mother nature can't make up her darn mind. It will be 70 one day, and 20 eight hours later.
    Dec 2003
    New York
    If you already applied the resin to the cloth then I would suggest you put a space heater next to where your working to help the resin cure.
    Installed
    Frisco, Texas
    I put down one strip with the "too thick" resin. No worries though. Today was about 40 degrees all day... Tomorrows forecast is all Sunny and about 64. Rollercoster weather... Makes it hard to plan a wardrobe...
  1. Auto on not working in the cold
    By scooby-rex in forum LCD/Display
    Last Post: 12-01-2005, 01:18 PM
  2. harddrives withstanding cold temperatures?
    By Nick DC in forum Newbie
    Last Post: 12-11-2004, 10:37 AM
  3. WTB: Cold Cathodes and Underglow
    By kiltjim in forum Classified Archive
    Last Post: 11-02-2004, 07:45 PM
  4. carputers and cold weather?!
    By mrzigzag in forum General Hardware Discussion
    Last Post: 08-06-2003, 02:00 AM
  5. Remote freezes when cold
    By RaZor in forum General Hardware Discussion
    Last Post: 01-01-2002, 11:15 AM
