Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: screen in my mini
    Variable Bitrate mutilator's Avatar
    Jul 2002
    Staffordshire - united kingdom
    Talking screen in my mini (it begins)
    just started to make a bezel for my mini, im movin the heater controls down, and puttin the screen where the hu/heaters were.
    its a 7" vga toucscreen, and will be on show all the time.
    Pics here
    im also gonna try to put a slot loading dvd drive in underneath the screen.
    im gonna power the screen off an itps, and i will use the power on pulse to powe r on the screen, so i wont need the buttons. (i hope) but ill solder a ir eye in my bezel just in case i need to control the screen.
    what do i paint it with? i was gonna just prime loads, and then spray like 4 times
    then laqure. should look ok?
    thanks,
    tom.
    Tainted Love Cris's Avatar
    Romania
    That looks really awesome. The detail work is fantastic. Keep the pictures comming.
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    How did do all that work? Looks like it was done at a professional woodworking shop. Did you use a router for all the detail? How did you get the perfect rounded corners? Thanks.
    -HD
    Jul 2002
    well i cut the hole with a router first,
    then i moved the guides out, to create a rebate.
    this left me with a rebate with rounded corners and a hole with rounded corners, (because the router cuts like that.)
    so i grabbed a chisel and squared off the corners to alow the screen to fit. i was gonna do that with the hole too, but i figure it looks good with round corners.
    next i rebated the front (to alow it to go into my cars dash) and then cut it using a table saw, and a crosscut. (if your doing it like this, cutting thin pieces, or rebated, mine was like 4mm away from the top of the rebate, and the rebate is around 1mm thick, if your doing somethin similar, make sure to fix to a piece of scrap wood, to keep everything together, will give cleaner cuts and stop the saw blade from messing up the thin edges)
    then i just grabbed some sand paper, and i feathered off the edge around the hole, so that when the screen is in, it meets the screen at a point. this makes it all very delicate, but once the screen is in it should be fine.
    im a joiner so i was a professional shop
    tom.
    How much for the screen and where from? Any vga hook up pics?
    Jul 2002
    its the tview one. i got a few and sold em on ebay. think you can get em off linitx.co.uk or something now.
    tom.
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Looking good tom
    Will it be finished in time for the next Car PC event? Looking forward to seeing it (and see if you don't win most ghetto this time )
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Jul 2002
    should be finished for the next event. i was goin for ghetto haha.
    tom.
    Raw Wave
    Jun 2004
    On the beach
    bugger - wish mine would look that good - it looks pants at the moment!!! I can't even get the cut out section straight!
    Jul 2002
    hehe keep at it.
    do you have access to routers etc? are you replacin the bezel same as me?
    tom.
  1. Anyone care to help me with a mystery screen?
    By Rover_Eli in forum LCD/Display
    Last Post: 03-27-2007, 07:34 PM
  2. Replies: 4
    Last Post: 01-29-2005, 06:35 PM
  3. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
  4. NEC Versa M/75 Laptop TFT screen w/touch
    By Macgyver777 in forum LCD/Display
    Last Post: 03-24-2002, 02:14 AM
  5. Laptop/LCD screen hookup...
    By UrbanTacticz in forum LCD/Display
    Last Post: 11-28-2001, 05:49 PM
