Results 1 to 10 of 12
Thread: Custom Enclosure, Ideas Welcome
    Variable Bitrate nsmoller's Avatar
    Dec 2004
    NY
    i had my uncle make up this for me, see attached (i dont know how to put them in a post - please help!)
    i told him i had to be able to put stuff in there and sleep on it if i need to, which made it kind of high (2x6's)...
    its very sturdy...
    we are going to carpet it grey, and we need help on ideas for cool stuff to do...
    inside will go carputer, dssc, inverter, ampx2, xbox soon.
    Proposed ideas:
    1. cut into 4's, 3 will be electronics, 1 will be storage. Top will be hinged, and a door will be over the storage area
    2. 10 or 12" sub in the box, only problem - cargo liner! i need to protect that, and the sound would be muffled
    any other thoughts???
    [4Runna]
    next - wifi
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    FISH TANK!!!
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by nsmoller
    its very sturdy...
    no ****! how much does it weight! I couldnt put that in my little 1.6 or i'd never get up hills!
    you need to vent it - use baffled vents and mesh to stop things falling in and shorting out your PC.
    Dec 2004
    NY
    Quote Originally Posted by Scouse Monkey
    the thing is closed dude, nothings gonna fall in...
    vent it why? heat?
    i may put a fan in the front then in the pc section, like a case fan or 2
    [4Runna]
    next - wifi
    Dec 2004
    NY
    Quote Originally Posted by scott_fx
    FISH TANK!!!
    i was like, noooo....
    then i started thinking.... how freakin phatty
    like a top down view of a fish tank??? that would be schweeeeeeeeet
    [4Runna]
    next - wifi
    Constant Bitrate old_lou's Avatar
    Oct 2004
    UK Midlands
    If you make the top out of a piece of ply, jigsawed to the exact size of the space. Cover it in carpet, a casual observer will think its the floor of the boot instead of an intresting box that may have something valuable in. But it is a bit big for something you want not noticed.
    EPIA MII: 512m Ram: LinITX 8" Touch Screen: Carnetix P1290 PSU: 802b PCMCIA Wireless card: Slot DVD Player: Touchpad: Wireless Keyboard: BU303 GPS Mouse:
    Win 2000: RoadRunner Front End: Michelin Mapstore GPS: Netstumbler:
    Dec 2004
    NY
    ok sorry to misrepresent my original post....
    THIS IS THE UNFINISHED PRODUCT!
    it will be carpetted GREY
    the doors will have HINGES
    there are shelving systems you can buy for $500 that are the same size
    the "picclosed.jpg" is the product with the top on !
    [4Runna]
    next - wifi
    Frisco, Texas
    Not bad. Just a thought though... You could use that as a good mold to make the same thing out of fiberglass and save alot in weight.
    Dec 2004
    NY
    Quote Originally Posted by TheJack
    ya i know, but i had someone else make it, and u know the weight isnt a problem since its a big truck... i told the guy who made it the important thing is that its sturdy, since we will carry ***** around and use the truck as our tent...
    what i want to know is if i can make a custom sub enclosure that will fit in those gaps in the back by the tailgate, i want them to face the driver and kinda fit to the curved rear of the truck.... thoughts on that?
    [4Runna]
    next - wifi
    Mar 2004
    Bristol
    It will if you put vents in!
    vent it why? heat?
    Why else would you add a fan????? If you just put a fan in there with no vents you wll just be moving the hot air around. You are gonna have a PC with PSU and HDD, 2 amps and an xbox - it is gonna get a lil warm and if its quite low then there will be no room for the hot air to rise away and cool. I would think about some vents aroudn the edges maybe with fans to blow out and somewhere far away and on the other side of the PC to allow cooler air to be drawn in.
    you may not get overheating as such but the constant higher than normal temps will probably reduce the life of your components.
  1. Fiberglass Sub Enclosure project
    By shillier in forum Fabrication
    Last Post: 02-06-2009, 03:30 PM
  2. CarPC Brainstorming Ideas
    By Bugbyte in forum General MP3Car Discussion
    Last Post: 12-27-2004, 02:40 PM
  3. creating a custom enclosure
    By cash_Money in forum General Hardware Discussion
    Last Post: 12-07-2004, 06:12 AM
  4. Custom enclosure for a Dodge Neon, Amp, & Subs
    By tejohnson in forum Classified Archive
    Last Post: 06-17-2002, 12:38 PM
