Results 1 to 10 of 10
Thread: What should I use?
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    What should I use?
    I have a small opening, that I need to make only slightly bigger. I want to fit a police scanner into my ash tray opening. The scanner is only slighlty larger than the existing hole, but when I'm finished with it, I want it to look as stock as possible.
    I was thinking I would start playing with fiberglass or bondo or whatever else I might use, but I have never done it before, so I really don't know what to use.
    It's a small hole, I don't really think I need to redo the entire bezel for this project. All I really want to do is have the bezel come to a corner around the scanner, and have a slight border following back behind the edge.
    Is this something as simple as bondo? Or would I need to use fiberglass and all that related stuff? I just really need a starting point, I can find the related informaion from there.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Nov 2004
    Arent police scanners illegal??? You sure you want to mold it into your dash?
    Nov 2004
    And to help you with it I need to see some pics.
    Feb 2004
    PA, USA
    There not illegal in PA, either base station, or mobile, so I don't have to worry about that. And If I get into a state that doesn't permit them, oh well.
    Here's a picture.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
    Dec 2003
    its hard to tell the size difference from that angle. whats the dash made of?
    Low Bitrate Vacheron's Avatar
    Jan 2005
    Newcastle UK
    I needed to do something very similar to mount my TFT in a my double din slot.
    This also involved just extending the existing opening downwards slightly into the ashtray area. the dashboard material also looks very similar to yours.
    I used a flexible bumper filler and black bumper paint to ensure a good bond to the the PET plastic. This also allowed the finished panel to flex during installation without cracking.
    Details are in my project log section 2.
    Elsewhere
    Quote Originally Posted by IxTanGxI
    No.
    How about the Wiki?
    Feb 2004
    PA, USA
    Quote Originally Posted by Tred
    Whats the dash made of?
    You know, I really don't know. Its plastic, thats about all I could tell you. I don't know if its PET or ABS, or what. But it is all plastic. There isn't anything on top of it, or anything behind it really.
    As for the size difference, it is only about 1/2" on either side, or about an 1" total.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
    Dec 2003
    even that shiny stuff surrounding the cig lighter? can u take some more pics?
    Feb 2004
    PA, USA
    I finally got some more photos of the bezel. Turns out its easier to take pictures with the bezel out of the car. I was hoping to keep the outlet where it is and work around it. But I'm also thinking about getting rid of it, and putting some switches where it is now.
    The shiny stuff around the cig. lighter is metal. The entire rest of the bezel is plastic.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
