Results 21 to 30 of 39
Thread: fiber glass box thickness
  1. #21
    _
    Mar 2004
    Little Elm, Texas
    mkay - just wondering.....it's completely the opposite of what most SQ experts would recomend.....but if you like it then more power to you!
    Jan Bennett
  2. #22
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    ok well, i dont remember if thats mdf or particle board now haha. but ill put a layer of resin. how can i tell if its mdf or particle? lol
    Well i Stood on it and it held it didint make a sound at all im thinking the thinist point is about 1/4" now
    curiosity...are u against getting nylon roap and cutting it to fit in the box, soaking it in resin and the glassing it to the inside of the box? it works great for strengthening just like using ribbing in anything else greatly strengthens the structure...
    Kevin
    and putting it around the edges?
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
  3. #23
    Feb 2005
    check out Harry's Audi..he did something very similar and his car is considered to be one of the best sounding cars on IASCA the circuit...depending the cutoff frequency and dispersion pattern of the tweeters this can and has worked very well ....
    Kevin
    Quote Originally Posted by Red GTi VR6
  4. #24
    Feb 2005
    it doesnt matter which one u use to be honest....there are reasons why u would want to use one type of wood over another but for your application it doesnt matter one bit audio wise, especially since u have bonded glass to the wood...if u can stand on it i believe your safe .....one infinity driver isnt going to blow up any decent enclosure...actually i dont think it would blow anything that can support it's weight..the compression just isn't enough IMO....i would reinforce the corners or seems as thats where u might have issues as the enclosure ages...using any type of wood glue makes this moot tho especially since u dont have something like a W7 in there...if u have never tried to break two properly glued wood joints i suggest u try it...the joint is stronger than the wood...
    Kevin
    Quote Originally Posted by WebDog
  5. #25
    yea i put liquid nails on all the seems. I definatly know its safe, i was punding the sub hard even before i put the additional kitty hair on. but i want to push the system hard. I got a 3 yr warantee that if i blow the sub up they will give me a new one.
    1990 Jeep Cherokee
  6. #26
    Feb 2005
    i think your good...enclosure looks great BTW...
    Kevin
  7. #27
    Thanks ill post some phots when its all done and painted/ installed.
    1990 Jeep Cherokee
  8. #28
    _
    Mar 2004
    Little Elm, Texas
    please do!
    Jan Bennett
  9. #29
    Well i got the sub mounted to test it agian and it sounds so much better.
    I got one more question how much did it cost to get yours covered in vynal?
    and is it just the top or is it on the sides and stuff?
    1990 Jeep Cherokee
  10. #30
    Constant Bitrate kalito's Avatar
    Nov 2003
    ny
    Talking
    Quote Originally Posted by TundraT3
    i want to check it out ... have any links
    98.8 complete
    95 chevy blazer s10
  1. Fibre Glass Tutorials
    By stillnocar in forum Fabrication
    Last Post: 01-02-2005, 04:43 PM
  2. sub box
    By pimpJ in forum Car Audio
    Last Post: 09-27-2004, 06:07 PM
  3. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 04:59 PM
  4. Case design for a stowage box.
    By nibix in forum Fabrication
    Last Post: 07-10-2004, 05:12 PM
  5. M10000n Box
    By mikeyg35 in forum General Hardware Discussion
    Last Post: 04-05-2004, 10:22 PM
