Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: fiber glass box thickness
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    I have been building a new sub box for my new 12" infinity sub. i have about 4-6 layers of fiberglass matt + a layer of fleice .
    I cant flex it anywhere do you think its think enugh?
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    _
    Mar 2004
    Little Elm, Texas
    how thick is the fiberglass mat that you are using? how thick would you say you are right now? 1/2"? 3/4"? 1"?
    how much resin did you pour on the fleice and let kick before putting the mat on?
    as long as you don't have any air pockets you should be fine.
    if in doubt, put another layer on.
    also, do you think you could stand on the box without it flexing? if so then I would say you are good to go!
    Jan Bennett
    I used about 2 1/4 32 Oz resin cans and you can see how thick it is, im not gona try standing on it since im a big guy...
    What do you think? should i throw 2-3 more layers on and use the rest of the resin i have?
    EDIT: if i add another layer sould i need to sand off the bondo?
    1990 Jeep Cherokee
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    It depends on the shape of the fiberglass. If its a flat area it will need to be twice as thick as an area with compound curvature.
    Fabricator
    well heres a pic of the box not much flat at all. let me know what you think.
    1990 Jeep Cherokee
    _
    Mar 2004
    Little Elm, Texas
    if in doubt - just put more layers on.....btw - have you bondoed it for the last time yet??
    Jan Bennett
    Constant Bitrate kalito's Avatar
    Nov 2003
    ny
    http://www.caraudiohelp.com/newslett...***_layers.htm
    that's what i did and i think it work i also used about 3/4's of a galon of kitty hair from the inside to reinforce the edgesand the walls...
    http://www.cardomain.com/memberpage/465067/3
    that's my final product i can crank it up to almost the max and it hasn't come apart...
    yes it is very small box but i kicks and i need to X-tra space...
    "baby coming in 5 month...."
    98.8 complete
    95 chevy blazer s10
    _
    Mar 2004
    Little Elm, Texas
    good find Kalito!
    that's an interesting tweeter arangement...why did you end up going with it?
    Jan Bennett
    Quote Originally Posted by Red GTi VR6
    I Think when the sun comes out this weekend ill put a few more layers on just to be sure. Thats not my final bono job i just wanted to get a better looking / smelling product to stick in my car to test, it hits hard i need to fill with poly fill and test again. that was actualy just one layer of bondo.
    So you think i need to remove the bondo? or can i just put a few more layers on top of it?
    1990 Jeep Cherokee
    Low Bitrate killerfishes's Avatar
    Dec 2003
    I would rip "not cut" one more sheat of mat into bits the size of your open hand and apply it to the inside.
    now working on my Dodge Dak
    toshiba portege == done
    audigy2 NX == done
    7" flush mount == 0%
    pimp rating == 48%
  1. Fibre Glass Tutorials
    By stillnocar in forum Fabrication
    Last Post: 01-02-2005, 05:43 PM
  2. sub box
    By pimpJ in forum Car Audio
    Last Post: 09-27-2004, 07:07 PM
  3. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 05:59 PM
  4. Case design for a stowage box.
    By nibix in forum Fabrication
    Last Post: 07-10-2004, 06:12 PM
  5. M10000n Box
    By mikeyg35 in forum General Hardware Discussion
    Last Post: 04-05-2004, 11:22 PM
