Page 14 of 27 FirstFirst ... 456789101112131415161718192021222324 ... LastLast
Results 131 to 140 of 269
Thread: Plans to offer a VW MK IV LCD faceplate - everyone please read.
  1. #131
    Constant Bitrate mbuchman's Avatar
    Feb 2005
    Quote Originally Posted by rushnrockt
    hmm, R32 bezel are not plastic, does that mean they are not stock and not good enough?
    Sorry, I never have seen an R32 inside before. You guys were talking about getting black ones or something to make them look more stock, so I assumed plastic.
    The mold I was talking about would be pretty basic, just have a top and a bottom to it. Like I said, it might not be possible, but it doesnt seem too hard.
    Also, did you consider of making them out of a different material? Like maybe a block of some other material would be cheaper, quicker (as in the CNC machines could cut them faster), easier on the machines (keep that carbide nice and sharp, itll make the shop happy), and all that good stuff. Or if you made the mold like I said above, you could just mix up fiberglass resin and pour it in. Just trying to give you some ideas to help cut cost.
    Matt
  2. #132
    Newbie FUZE's Avatar
    San Jose
    How are R32 bezels not plastic? Seemed like plastic to me when I drove my soldering iron through it to make a hole =D
  3. #133
    Nov 2004
    Well considering you drive a Jetta...
  4. #134
    Nov 2004
    Cali
    Quote Originally Posted by FUZE
    The one I was looking at had aluminum, you sure you were not driving an R32 version of Jetta? The one that has 6-wheel drive and a rocket engine?
    I have found you an argument; I am not obliged to find you an understanding.
  5. #135
    Low Bitrate Stonewall78's Avatar
    Dec 2003
    Calgary, AB
    You mean a GLI?
    Aluminum dash kits are an option on all VW's they just need a different radio cage. BTW a plastic mold will run you about $15,000 for a job like this.
  6. #136
    Nov 2004
    Cali
    Quote Originally Posted by Stonewall78
    You mean a GLI?
    No no, i didn't mean a GLI, I meant precisely what I said
    And I was under impression that R32 was a kind of car to have too many options. Well, I think the R32 owner here should correct our misconceptions. Eventually.
  7. #137
    Low Bitrate crazymadbastard's Avatar
    Jan 2005
    Connecticut
    HELLO,
    Just saw this in another post:
    http://www.frontpanelexpress.com/home/index.htm
    don't know if you looked at this...
    Iwill ZPCgx 2.4ghz cel, 256mb pc2700, external combo drive, 80gb 2.5 laptop drive, xp pro, usb gps, 7 in Lilliput TS , carnetix CNX1900. All mounted ghetto- still experimenting and tweaking.
  8. #138
    Feb 2005
    New Orleans, LA
    R32-
    Don't know if this has been mentioned in this post, but I was wondering how the faceplate attaches to the dash, are there clips or what? I have a MK3 so this faceplate wont work for me, but I am molding my own and have no idea how I should attach it to my dash.
    Thanks in advance.
    1997 VW Jetta GLX VR6
    old HP MP
    PIII 600 or so 256 MB
    7" Xenarc
    and some plywood holding it all together
    My Project
  9. #139
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    sorry if this is out of place... i didn't reat the thread fully, but would be interested in a MKIV Passat one... It's not that much different, only wider...
  10. #140
    Maximum Bitrate R32 JUhl's Avatar
    Nov 2004
    North Atlanta
    Quote Originally Posted by crazymadbastard
    HELLO,
    I'll check it out. I've already invested a good bit of money for the drawings with the machine shop, though...
    Quote Originally Posted by Iatrogenic2
    R32-
    Thanks in advance.
    The faceplate is using the Mapower enclosure for the primary means of fastening. The faceplate mounts to the enclosure then the enclosure is secured to the radio bucket. Once the faceplate is complete, if there is additional need for support at the top, that will be facilitated with screws-on clips.
    Quote Originally Posted by BoyNextDoor
    I can do it... I will simply have the same request as I had for the Golf/Jetta - a donor radio bucket and a dash - so I know everything fits and have the measurements/specs.
    My first attempt at a carputer.
    PM me if you're interested in a monitor faceplate for your '99-'04 Golf or Jetta. My Vortex ID is NorthAtlR32 - you can IM me there, too. Go here for more information.
