I might be able to help you out here. You can see pictures of my fabrication here:
We should talk. I'm in a MKIV Jetta VR6.
I can provide you with a spare center console, etc. and I'm in North ATL.
Kind regards,
CB
Revised 7/1/05
To all interested:
Upon posting the pics of my my carputer install, I got a lot of requests to supply a faceplate for other MK IV Golf & Jetta installs. There's not enough free time for me to hand-build the units I have requests for, so I have gone to a machine shop to get the faceplates made by machine from aluminum. The unit takes the place of a double-Din radio and the cupholder. It houses a Lilliput LCD and a Mapower DVD enclosure.
I'm not looking to get rich on this project! I simply wanted to offer a unit to those who don't have the abundant free time required to make their own piece or for those who don't have the skills - I thought I was one of the latter three months ago.
If there is a desire for a Xenarc-capable faceplate, then I need a donor Xenarc. If I can make enough money to buy a Xenarc, then I will. But that will delay creation of the Xenarc bezel as well as add cost to it.
Special thanks to DashPC.com for the loaner MK IV radio bucket that's helping to keep the "per unit" cost down a couple of extra bucks as well as make it simpler to test prototypes and perform measurements. Thanks Chris.![]()
Load up my PM box and help me keep this thread near the top!
STATUS as of 7/1/05:
I've been forced to start over on this project!If you want to read through the thread, you can see the problems I've had with incompetent machine shops. I'm in the process of making an acrylic model from scratch to provide for a machinist to make their design from. I'm handling multiple projects in my personal (as well as professional) life that are requiring an abundance of travel, time, energy and resources. I will steal time for this project as I can. Sadly, it is a project that does not travel well so I cannot take it with me to work on in a hotel room - otherwise I would.
My first attempt at a carputer.
PM me if you're interested in a monitor faceplate for your '99-'04 Golf or Jetta. My Vortex ID is NorthAtlR32 - you can IM me there, too. Go here for more information.
Kind regards,
CB
DashPC - The Linux Car (since 1999).
Dash LCD, Via Epia, GPS, XM, OBDII, DSSC Shutdown Controller.
As seen in the book Geek My Ride
it's not that hard people!
really!
I don't want to ruin your post R32 but COME ON PEOPLE!
there are a ton og MKIVs on here who have done it so it must not be that difficult!
ok - I'm putting my flame suit on now
Jan Bennett
You're right - it isn't difficult for someone with your level of knowledge of fabrication. Even I figured it out after making a few mistakes. What IS hard is spending the time it requires to research, to learn how to fabricate, to formulate a plan, to draw up the plans, to come up with the tools to do it, to come up with the materials to do it, and again to come up with the TIME to do it. Time is money! And the 15 or so hours I dedicated to fabrication, not including an equal amount of time I spent getting everything together multiplied by what my employer says my time is worth, makes my dash piece worth well over a thousand bucks. If someone offered a solution for a hundred bucks, I would have saved over a thousand dollars. And that's how a lot of people who are pressed for time have to look at it. For a lot of people, it isn't just about the skills, it's about the cost of time - you never get that back, but you can always find a way to get more money.Originally Posted by Red GTi VR6
No flaming required.![]()
Read, "The Richest Man in Babylon". It's a quirky book, but it puts my statement in perspective. OH, it's a quick read, too!![]()
While I see where you are coming from I still can't understand it completely....I haven't read that book but I know generally what it's about.
It's not cool to do it if you can just buy a bunch of prefabbed parts and put them together and be done with it......
BUT
different strokes for different folks!![]()
Jan Bennett
You are so right!Originally Posted by Red GTi VR6
You got mail!Originally Posted by cbergeron
I own a MKIV GTI and would be interested in a faceplate to make my carputer install look cleaner and have more of an OEM look. Unfortunately I don't have a spare radio basket I could provide for prototype purposes, but hopefully there is someone out there that will send you one.
One thought on your design, is it possible to recess / angle the top edge of the screen about 15deg into the top and let the bottom edge of the screen be almost fush with the front face of the radio basket? It will help visibility of the screen by allowing a more direct view of the screen along with eliminating some glare. I am sure this will complicate the design if you decide to implement it, but it may be beneficial.
Great input! I think I may have a center dash piece committed to the project and am closing in on a Lili - possibly - more info later. Will keep this thread current with updates.Originally Posted by jasonsp6
Will a Xenarc fit in it as well? Members experience shows that Lilli's are not built well enough for removing and reinstalling like so.Originally Posted by R32 JUhl
