Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Fiber glass amp rack walk thrue.
  1. #21
    Low Bitrate killerfishes's Avatar
    Dec 2003
    this is the stuff im looking for. I know some one at an audio store and he talked me into letting him make me a box out of it and WOW.
    http://www.nelsonpine.co.nz/liteboard.htm
    now working on my Dodge Dak
    toshiba portege == done
    audigy2 NX == done
    7" flush mount == 0%
    pimp rating == 48%
  2. #22
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    Ehh so why did the fiberglass not stick to the amp rack?
    CarPC install is starting to come along again...
  3. #23
    Dec 2003
    I did not fully saturate the fleece with epoxy, I used over half a gallon and was only like 3/4 saturated.
    audigy2 NX == done
    pimp rating == 48%
  4. #24
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    did you staple the fleece to the mdf?
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
  5. #25
    IQ < < 70
    Mar 2004
    it doesn't need to be 100% saturated. you need to layer it, use the fiberglass mesh to put it on top of that, nobody will look into the custom shape.
  6. #26
    Quote Originally Posted by dim-8
    thats correct, when i built my new sub box the back side was stil soft. then i put layers of mat on.
    1990 Jeep Cherokee
  7. #27
    Dec 2003
    the problem is that once i cut it to fit the amp in it was too lose on the MDF and i just was not happy with the shape, I could have saved it but it would not have been the way i wanted it.
    audigy2 NX == done
    pimp rating == 48%
  1. del
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 02:41 AM
  2. fiber glass box thickness
    By WebDog in forum Fabrication
    Last Post: 02-15-2005, 07:12 AM
  3. Finally Finished Amp Rack
    By Snootch in forum Car Audio
    Last Post: 06-08-2004, 05:31 AM
  4. system layout configuration (amp rack) question
    By traitorhound in forum General Hardware Discussion
    Last Post: 06-18-2003, 12:24 AM
