Results 1 to 5 of 5
Thread: this isnt as easy as 1 2 3
    Sydney, Australia
    Thumbs down this isnt as easy as 1 2 3
    Hey guys ive searched and stalked these threads for ages.. (unfortunately most of those resource sites are down or more confusing)
    But i havent found anything that mentions the basics...
    Now take pity on this clueless student in sydney.. have i got this right?
    You have fiberglass stuff which involves resin
    Where u build a frame, stretch certain suggested material across, then douse it with resin (in stages) until the shape is built up and strengthened.
    So if you need to build a shape from scratch, fg is the way to go.
    What is epoxy by the way...
    Now bondo... is this just a brand of.. something?
    Coz i went to the hardware store and mentioned bondo i received a funny look in return. (so it may not be readily available here in aus).. What is this stuff? similar to fiberglass resin?
    It seems that if you have a shape and just want to build it up a bit and smooth it out, then this is the way to go.
    I wanna try and have a go at making an indash housing for the bimmer toooo.
    Both Fiberglassing or bondo-ing requires alot of sanding and reapplication. Then you use a primer to get it all smooth and paint.
    So this is my understanding... Id appreciate someone filling in the gaps for me.. thanks guys!
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    Bondo is a name brand for plastic body filler. You shoulc be able to get something simular at a auto parts store or auto paint supply store.
    You might want to go and look at these demo cars. They have an install and finish photo album.
    Sydney, Australia
    sweet thanks!
    now i know wat to ask for when i go into a store
    Mar 2004
    Little Elm, Texas
    did you see the fiberglass how to at the beginning of the fabrication forum?
    I'm assuming so....
    one point....when you think you have sanded enough, sand a bit
    and do it with a block so you don't create a wavey surface
    Jan Bennett
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    G-Han, you need to come to the Sydney meet this Sunday. Sydney Meet I'm sure that you could learn a lot more from talking to the guys face to face.
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Easy way to run rotary encoders
    By TheLlama in forum Input Devices
    Last Post: 02-15-2005, 05:01 PM
  3. when painting dash trim does paint flack easy?
    By sr_ryan1 in forum Fabrication
    Last Post: 10-09-2004, 10:28 AM
  4. 24 Volts, Possible? Easy?
    By Deadnick in forum Power Supplies
    Last Post: 05-26-2004, 10:47 AM
  5. Cirque Easy with USB converter
    By CoCa in forum Input Devices
    Last Post: 04-02-2004, 08:19 PM
