Results 1 to 10 of 10
Thread: Thinking of buying a small mill / lathe..
    Feb 2004
    I have a sizable tax refund coming to me soon, so I was considering getting a small milling machine or metal lathe so I can build more stuff.
    Has anybody used these machines from MicroMark, or similar?
    MicroMark MICROLUX MILLING MACHINE
    MicroMark MICROLUX 7 x 14 HIGH-PRECISION HEAVY-DUTY LATHE
    Supposedly the mill and lathes are made by a company in China, Sieg Industries:
    http://www.siegind.com/
    http://www.siegind.com/mill-y.htm
    http://www.siegind.com/lathe-y.htm
    I'm only looking for a benchtop or tabletop machine, as most of my work would be limited in size.
    Anybody with machinist experience have any comments?
    I've wanted a mill/lathe ever since I worked on a Bridgeport mill in High School, and a giant metal lathe even before that..
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    I've been wanting to get a benchtop mill too. I've got access to a large one at work, but man, I want a CNC mill (from what I've seen, decent hobbyist-class CNC mills go for around $1500...)
    Feb 2004
    Quote Originally Posted by mushin
    Plans to convert these mills/lathes to CNC versions go for about $50..
    I believe the estimated cost for a CNC retrofit, making the parts yourselves, is somewhere between $300 and $600, on top of the ~$500 for each machine..
    Aug 2004
    SE Michigan
    So how're you planning on doing a $300 - $600 retrofit for $50? If you decide to go forward, I'd definetely be interested in your plans/results. I'd be all over a $550 CNC mill!
    edit: oh, do you mean the cost of the plans are $50, and the cost of actually doing it are $300 - $600? Phooey.
    Feb 2004
    Yes, exactly.
    Plans are $50, cost to do it is $300-600..
    However, I don't think that includes all the necessary components, like the stepper motors, controller, etc..
    Newbie vajimbo's Avatar
    Dec 2004
    Hampton VA
    why would you need a CNC? Are you going to start making 50 or more of each part. If you are going to make a few parts it would be faster to do it non CNC setting up the CNC takes time that will only be paid back if you run manny parts. The trick is knowing what to do when and how to do it.
    I have not used the mil or lath you show but would think that you could use them for smaller projects that did not need +-.001" they should be able to do .010"
    Feb 2004
    Quote Originally Posted by vajimbo
    Oh, I wouldn't need CNC from the start, but it's a neat idea that there are plans out there for conversion.
    And I think this mill can do .001 tolerance - the dials are .050" per turn.
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Before I bought my current machine (not benchtop, so my model would mean nothing to you) I was looking at some of the smaller machines. I may have looked at the machine you have there, but I would never remember. The problem that I had with the smaller benchtop models was that they were not very stable machines. Even with smaller parts, there was significant chatter. The machine itself seemed put together well enough, but I wasn't very satisfied with the quality of the work.
    My .02
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Feb 2004
    Quote Originally Posted by kiltjim
    My .02
    So what kind of a mill are you using?
    And how much was it?
    Got any pics or links to a similar model?
    Feb 2004
    PA, USA
    I am using a Grizzly brand. I have no idea what model (I'm at school, so the machine is about 6 hours away.)
    It isn't the greatest of quality. But, there is very little chatter when trying to cut a straight line. I ended up buying a combination lathe/mill. I can cut pretty much anything, but since its a combination machine, I have limitations with length. But, nothing I have done so far couldn't be done on this machine.
    It was about $1000 or so if I remember properly.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
  1. Was thinking about buying this
    By bosstone74 in forum Off Topic
    Last Post: 12-06-2002, 02:56 PM
