Results 1 to 10 of 10
Thread: Any functionality lost when buttons are covered?
    Nov 2003
    Olympia, WA
    So is there any functionality lost when the buttons of a Lilli are covered up? Can you still use the remote?
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Yes the remote is all you need but you need to relocate the IR receiver then.
    Fabricator
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    And hehe do not forget to relocate the power button. Or look around for auto-on power button mod.
    Nov 2003
    Olympia, WA
    Good thing I asked before redoing my install. Thanks!
    _
    Mar 2004
    Little Elm, Texas
    be sure to post pics of inprogress as well as finished stuff!
    Jan Bennett
    Oct 2003
    WI
    The remote has a power button.
    Fabricator
    Newbie Geron's Avatar
    Feb 2005
    Delawhere?
    What about if you cover up an Xenarc's buttons. Would the same apply?
    Would it work if you left a small hole over where the IR sensor is, in whatever your covering the buttons with?
    FLAC J187's Avatar
    Nov 2004
    Boston
    Personally, I covered all the lillput's button except the IR sensor AND the power button. Just in case, it was easy enough to just keep one.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Newbie yellow99's Avatar
    Dec 2004
    The Netherlands
    Quote Originally Posted by J187
    Do you have some pictures of that
    Oct 2003
    WI
    The Xenarc IR sensor is on a nice long cable as if they designed it to be relocated.
    Fabricator
  1. How-To: Relocating Screen Buttons
    By Altimat in forum Fabrication
    Last Post: 11-07-2007, 03:48 PM
  2. Replies: 7
    Last Post: 02-05-2005, 06:41 AM
  3. Where to get black Lilliput buttons
    By Quattro in forum LCD/Display
    Last Post: 09-14-2004, 07:49 PM
  4. Where To Buy Buttons, Switches, Lights?
    By eCar in forum General Hardware Discussion
    Last Post: 02-22-2004, 02:25 PM
  5. Illuminated buttons for custom console
    By mccleanp in forum General Hardware Discussion
    Last Post: 01-18-2002, 09:37 PM
