Results 1 to 10 of 11
Thread: how to remove dried resin
    Constant Bitrate minghi's Avatar
    May 2004
    Phoenixville, PA
    hi guys, i think i am done installing the screen in the dash.
    http://www.acuravigor.info/mp3car
    btw, how can i remove the dried resin shown in the last image
    400W Power Amplifier -$25
    P3 laptop mobo-$30ish
    128MB RAM-$10
    6GB+80GB 2.5" HDDs-$130
    GPS-$60
    7" TS Lilliput-$280
    10" pioneer 500w sub-$55
    sony xm-3020 30W amp-$10
    jensen 340W A34XP amp-$40
    mp3car.com resources and members- priceless
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    if its epoxy you wont be able to. You will have to sand it off as there is pretty mucn no chemical agent to remove it that won't wreck your dash.
    May 2004
    Phoenixville, PA
    Quote Originally Posted by Scouse Monkey
    its plastic weld, bought it at walmart.
    128MB RAM-$10
    GPS-$60
    7" TS Lilliput-$280
    Mar 2004
    Bristol
    Quote Originally Posted by minghi
    I have no idea what that is made from but to be honest it sounds pretty permanant. Try using a knife (carefully) and then maybe some emery to get the texture back in. if it still looks odd then you will have to paint it.
    _
    Mar 2004
    Little Elm, Texas
    wtf?
    lol
    did you not cover up the rest of your dash before using it?
    there isn't much at all that will get that off without needed to refinish that part of your dash....
    and just to be clear on how you have the screen installed....did you just make a 'plate' to mount the screen mount to then just screw the screen to that mount?
    what's the fabric? just to prevent it from rubbing?
    Jan Bennett
    May 2004
    Phoenixville, PA
    well, i guess i shud have, but was too excited to get this done. thus paid the price
    nope, the 'hole' in the dash is little smaller than the lilliput dimensions. now, the 'lilliput stand' is fixed behind the lilliput. i did not remove the paper(glue) under the stand. then using a bungee cord from ace hardware, i just made a knot and fixed it to the two sides of the dash. this will prevent it from falling forward. and if i want to remove the screen for any reason, just in case, i just pull the screen and move the bungee cord aside. not sure, if i was able to explain it clearly, but i will send you a picture if you wish.
    its foam from an uphostry shop. used to fill the gap between the screen sides and the dash.
    Quote Originally Posted by Red GTi VR6
    wtf?
    lol
    128MB RAM-$10
    GPS-$60
    7" TS Lilliput-$280
    _
    Mar 2004
    Little Elm, Texas
    interesting.....=]
    Jan Bennett
    Dec 2003
    ouch.. that doesnt look pretty
    you can try one of two things, take of the screwed up bezel:
    1. start sanding that stuff away and then repaint it
    2. sand a little bit and re-dip the part in resin
    _
    Mar 2004
    Little Elm, Texas
    re-dip? why? to give it a more even look?
    Jan Bennett
    May 2004
    Phoenixville, PA
    do you have any particular brand name in mind for the paint and resin.
    Quote Originally Posted by Tred
    128MB RAM-$10
    GPS-$60
    7" TS Lilliput-$280
  1. Remove Taskbar
    By GARB-E in forum WinNT Based
    Last Post: 04-05-2012, 08:57 AM
  2. [WinXP] Manually completly remove Driver
    By antimatter in forum Software & Software Development
    Last Post: 11-19-2004, 02:33 AM
  3. Where to get polyester fiberglass resin and ...for cheap....
    By Seabass in forum General Hardware Discussion
    Last Post: 07-26-2003, 10:00 PM
  4. Fiberglass resin questions
    By ddt in forum General MP3Car Discussion
    Last Post: 10-02-2002, 02:07 PM
