First off check the specs of your amps most will tell clearance needed over them, well atleast my JL amps did. You are definally going to need atleast 2 fans, one push one pull. I built a circuit that keeps the fans on one minute after the amps are turned off for good measure. You can see how I did my trunk here : link although the picture are now outdated.
LinkBack URL
About LinkBacks
