Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Can u make a Bent PCB???
  1. #11
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    acrylic will melt when you are soldering the wires to the legs and the components will end up all loose.
  2. #12
    I would just use several small peices of pcb to put the legs of the led's and what not threw solder wires all together then just epoxy the pcb that is on the bottom of the led and glue it to what ever u decide to use for your curved surface.
  3. #13
    Apr 2005
    You can solder the led legs at the tip and bend them in which direction you want to should sole the problem.
  1. Replies: 16
    Last Post: 09-05-2007, 05:19 PM
  2. Opus 90W: PCB module or Open frame?
    By dormouse in forum Power Supplies
    Last Post: 10-01-2003, 02:04 PM
  3. sproggy 2.8 PCB anyone?
    By stimps in forum Power Supplies
    Last Post: 05-31-2003, 07:36 PM
  4. Have your friends make their own playlist!
    By dudah85 in forum General MP3Car Discussion
    Last Post: 08-14-2001, 11:19 AM
  5. how to make LED flash?
    By schrodos in forum General MP3Car Discussion
    Last Post: 01-14-2001, 07:39 PM
