Results 1 to 10 of 13
Thread: Can u make a Bent PCB???
    Constant Bitrate blackbravo's Avatar
    Nov 2004
    Southampton, UK
    For a little idea of mine just wondering if u can make a PCB Bent, Not bent when made but before???
    Like before u print track and fit leds, resistors ,Caps and such like??
    Cheers All
    Still Planning and Scavenging Parts ------Software-----and anything else i can lay my hands on!!! :)
    Acquired a Toshiba Satelite 4000CDT
    HDD`s ****ed new one on way! 30gb Toshiba.
    Low Bitrate killerfishes's Avatar
    Dec 2003
    you would need to have it made custom some where as the mica used will not bend. It will work if you can find a place to make it for you.
    now working on my Dodge Dak
    toshiba portege == done
    audigy2 NX == done
    7" flush mount == 0%
    pimp rating == 48%
    Nov 2004
    Southampton, UK
    Ok, thanks for the reply.
    Are custom mad ePCB`s expensive, its only gonna be a small board, very simple hopefully, 12 Leds, couple of resistors and maybe a capacitor.
    Constant Bitrate Caitlin's Avatar
    Dec 2004
    Manchester
    cant you use two with a link cable and join them in a bent shape?
    Cat
    Woot, or something.
    Epia M10000 (less rubbish than the 800) :: LCD touchscreen
    GPS :: 80G drive :: Not enough ram... Never enough..
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    PCBs are fibreglass so technically any shape is possible. But you would have to apply the copper cladding to an already curved piece of fibreglass.
    Best way it to use two boards as the Cat suggests and use ribbon cables.
    Aug 2003
    Melbourne, FL
    There is a such thing as a flex board. The PCB resembles a ribbon cable. There is NO point in going through that expense for this though.
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Quote Originally Posted by blackbravo
    For something that simple, you don't really need a PCB. Cut/bend a piece of acrylic into your desired shape, drill mounting holes for your components, and just connect them with wire.
    A small cheap basic PCB costs around $40 in single quantity. I've never seen non-flat PCB outfits, but I can't imagine it's cheap.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by mushin
    You will never achieve a good pattern with acrylic
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I think he's not suggesting using acrylic and trying to etch a board. Just bend it to shape and use hook up wire to connect the components.
    Want to:
  1. Replies: 16
    Last Post: 09-05-2007, 04:19 PM
  2. Opus 90W: PCB module or Open frame?
    By dormouse in forum Power Supplies
    Last Post: 10-01-2003, 01:04 PM
  3. sproggy 2.8 PCB anyone?
    By stimps in forum Power Supplies
    Last Post: 05-31-2003, 06:36 PM
  4. Have your friends make their own playlist!
    By dudah85 in forum General MP3Car Discussion
    Last Post: 08-14-2001, 10:19 AM
  5. how to make LED flash?
    By schrodos in forum General MP3Car Discussion
    Last Post: 01-14-2001, 06:39 PM
