If I understand you correctly, it's possible to do that mechanically. Just have the servo rotate past the toggle position to bring the slider back; meanwhile a second linkage can rotate the screen up/down. I say this because I have very little experience with microcontrollers, and the mechanical design wouldn't be that difficult to implement.Originally Posted by 89ragtopgt
Do you have a good way to make the LCD housing the right size? Or did you manage to find one that's already the right size? I tried doing some welding to make a housing, and I failed miserably because aluminum is very hard to weld and I'd never done it before.Originally Posted by 89ragtopgt
LinkBack URL
About LinkBacks
