Results 1 to 10 of 13
Thread: 1992 Mazda Miata In-Dash Project w/ 7" Lilliput
    Aug 2004
    Southern California
    Here are some pics of my progress. The first picture is a picture of the car itself. The second picture is of the lilliput project housing on top my radio bezel. It was much wider and taller than the opening I had to work with. In the third picture, I used a dremel tool to cut away some of the plastic so that the lilliput can fit properly. The fourth picture is of the lilliput glued onto the radio bezel with epoxy. The next picture is when I applied the plastic filler. After that it's sanding, filling, more sanding, and more filling.
    Aug 2004
    Southern California
    Here is a picture of the first coat of primer, I still need to fill in some pinholes and sand out some rough areas.
    Thanks to all the members who posted similar projects to make doing something like this much easier than expected.
    Nov 2003
    Olympia, WA
    Very clean install. Good job.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    nice! I like it
    肚子笑痛了
    S60 Install
    Jun 2003
    Memphis - TN
    Very Nice!
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Tainted Love Cris's Avatar
    Romania
    Now this is not a girly Miata! Awesome work on the dash. But I want to see more pics. Where is the computer placed?
    Aug 2004
    Southern California
    Quote Originally Posted by Cris
    Thanks for the kind comments everyone!
    Cris - I'll be uploading more pics as I get through the project, right now I'm on my third coat of primer. There always seems to be something I forgot to fill and sand! But it's looking much better. As for the computer placement, I was thinking about putting the epia in the glovebox (even mounted it and everything) but realized there is not really enough space. So I've decided to make a custom amp rack that I will mount on the wall behind the passenger seat, along with some plexiglass windows. I'll be sure to post everything here.
    Thanks again
    Constant Bitrate Meta's Avatar
    Dec 2004
    Indiana
    Quote Originally Posted by All4Sky
    Thanks again
    Looks great!
    I too have the PC sitting behind the passenger's seat. However, I didn't realize until after having a few people ride with me this week, how valuable that lost 2" of legroom is! (not much room in a Miata) I'm thinking of tearing up the carpet this weekend and see if there's a way to route the cabling to the trunk and put the PC there. I'm curious to see how you're going to do your custom rack.
    Aug 2004
    Southern California
    Quote Originally Posted by Meta
    Looks great!
    Meta - If the later miata models are anything like the older ones, you should find some channels into the trunk under the carpet. I know what you mean about the 2" of legroom! I used to have a cd changer mounted back there and some of my friends were pretty uncomfortable riding in my car! I'm not as concerned about that now because this car is not my daily driver anymore, it's more of my "fun" car. Another great location would be the dent in the trunk floor, not sure if your model has that still. I wasthinking of putting everything in there and placing a piece of carpeted mdf on top, with an acrylic window. I'll have to decide which route to go. Thanks
    Jan 2005
    Aurora, OR
    Great job! Getting ready to do the same thing....what brand and type of epoxy did you use and the same thing for the plastic filler? Thanks
  1. '99 Mazda Miata w/Media Engine
    By jhwelsh in forum Show off your project
    Last Post: 12-13-2004, 12:27 PM
  2. FS: 7" Lilliput Touchscreen VGA Monitor : Broken
    By jaeger in forum Classified Archive
    Last Post: 08-21-2004, 07:46 AM
  3. Replies: 5
    Last Post: 04-01-2004, 04:37 AM
  4. In-Dash 7" MOTOR TFT or Lilliput 7" Touch Screen
    By JonX69 in forum LCD/Display
    Last Post: 03-06-2004, 01:22 PM
