Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: to: mister altimat
  1. #11
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    no..... my qustion is, if after I glue it and is rigid I can use the metal glaze to fill the cracks,gaps etc(just like when fixing the ABS dash panel)?? or I need another kind of filler????
    So this will be the steps:???
    *Sand it and clean it.....
    *Use the 3M adheresion promoter(whetever directions it have on the lable), apply the 3M platic repair on the back and put tape on front.....
    *Use the metal glaze filler to fix the gaps on the front....
    So is this right????
    thanks Altimat for share your knowledge......
  2. #12
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Yes that should work. Just make sure it is rigid after gluing because polyester filler is not very flexible. It also doesn't stick to epoxy.
    Fabricator
  3. #13
    Nov 2004
    Thanks for all your help..... I really learned a lot of fabrication with your tips
  1. 2002 Altimat CarPC
    By Altimat in forum Show off your project
    Last Post: 12-05-2005, 12:53 AM
  2. Lqqk --> Altimat <-- LQQK
    By belezeebub in forum Fabrication
    Last Post: 12-05-2004, 06:05 PM
  3. Altimat new fabrication moderator
    By Zip-Lock in forum Fabrication
    Last Post: 11-13-2004, 10:57 PM
