Results 1 to 8 of 8
Thread: Dye vs. Paint
    Constant Bitrate ChaCha's Avatar
    Nov 2004
    Los Angeles
    Question Dye vs. Paint
    Can anyone describe the difference (if any) between these two processes? Are paint & dye interchangeable terms and if so, why do some people refer to paint and others use dye? I'm asking because I want to change the color of my dash pad ('01 Chevy Tahoe) and am not sure which approach would be better suited for that.
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    i would think you would want to dye that, the dye will soak in and not scrach or peel off.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    well a dye is added to the marterial and colours it throughout - as webdog says: it wont peel off.
    A paint is simply a coating that can affect the texture and finish but can peel off and chip. plastic is dyed, rarely painted. but the effect of dying is limited. if you can make a dyed firbreglass/epoxy dash the right colour and shinyness it should look better than a painted one.
    i would use dye if you can as it will soak in and should not make it shiny like paint will. If it goes wrong just paint over it!
    ddn
    ddn is offline
    Dec 2004
    You want vinyl dye. I used special stuff on vinyl Corvette parts and it looks amazing and the finish is NOTHING like paint. The piece literally takes on that color.
    Jan 2005
    Indiana USA
    i used paint on my dash pad on my 98 cavalier and it will not dry and will feel like flypaper forever. So go to an auto store and see if they have Duplicolor Vinyl and Fabric Dye. That is the only stuff that will work. I used that to change the color of my headliner from tan to black and the fabric in my back window. Its great stuff.
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Vinyl dye is just paint really. You can't dye vinyl, but they make paints especially for vinyl and call them vinyl dye. They do work very well even on seats and steering wheels.
    Fabricator
    Nov 2004
    Los Angeles
    Wow. Thanks for all the speedy replies.
    Dec 2004
    Do you guys know of any material that would create a factory molded abs type of finish? Its a smothe finish but matte so it looks grayish rather than grey
  1. Steps to sand and paint bondo?
    By nappyjim in forum Fabrication
    Last Post: 01-30-2005, 09:47 AM
  2. Very Unique Bondo Problem! Paint Screwing it up?
    By Grayscale in forum Fabrication
    Last Post: 01-09-2005, 11:34 AM
  3. Paint type
    By LittleDragon in forum Fabrication
    Last Post: 04-24-2004, 05:35 PM
  4. Car Paint Repair Question
    By Max018 in forum Off Topic
    Last Post: 03-12-2004, 12:03 PM
  5. new paint on the eT/A....
    By eT/A in forum Off Topic
    Last Post: 05-02-2003, 08:13 AM
