read this thread...lots of ideas...from pipe to legos to regrind.
1997 VW Jetta GLX VR6
old HP MP
PIII 600 or so 256 MB
7" Xenarc
and some plywood holding it all together
My Project
Thanks...time to destroy some LEGO!! hhahaha..
link posted above. This is really simple stuff to work with. I've used featherlight before and it's a 50/50 mix. Both are in liquid form and once mixed are poured into your mold or what have you. It cures in 20 mins. chopping up lego bits and mixing with acetone is the most assanine thing I've ever heard.Originally Posted by DK888
Well mr. assanine, it works. I offered it as an option for those that don't know where to get anything else. I don't really know what featherweight is, and I can already see someone claiming it being my ignorance, but I am only trying to help others, just like the post was started for.
EDIT: Featherlight I apologize.
featherlight is a two part pourable plastic that forms much harder than abs and is easier to work with than melting legos with acetone. I wasn't trying to start a flamewar at all, sorry if I came across that way. I found this site smooth-on.com by answering some of my own questions. How is abs plastic made? How can they inject it into a mold. A. It must be pourable therefore it must be a liquid of some sort. A search for liquid plastic revealed this company.
10-4. I apologize for jumping the gun.
PVC has one good use. Potato guns.Originally Posted by n8scstm
and bondage gear!Originally Posted by shotgunefx
apparently!
Ok.... I'm assuming that the ABS/acetone mixture is a bit on the thick side...or is it? And how thick is the mixture for Featherweight? I don't think i'm that advanced to start making molds but, I would like to mold my monitor to the dash as a beginning project. Hence, filling in the gaps that I already have. How much did the lego and acetone project cost? and how much does the Featherweight cost?
