How come you went with acrylic instead of the ABS?Originally Posted by Red Ranger
I got my acetone from Menards, It was like 4 or 5 bucks for a 32 ounce bottle. It was in the paint section. I have seen it at Auto zone also over by the touch up paint but that was like 7-8 bucks a bottle. Basically, any hardware store will have it. Check by the paint thinner (Acetone is an epoxy thinner)
As for the thickness, I have only used it with acryilic and it is pretty thin. kind of like a syrup. I put too much acrylic in my bottle and have a large lump of it in the bottom of it. I figure when i get low, i will just add some more acetone to the mix to thin it out and disolve the rest of it.
Brian
the featherlight trial kit makes 2 quarts is $20, that's a whole lot of lego's and acetone. It's as thick as water. I'd suggest filling in gaps with bondo or filler material. Before you start making molds you need a finished plug.Originally Posted by DK888
The case i built is acrylic and i want to make the top and sides one peice to make it a cleaner looking install and all the sides meet together.Originally Posted by DK888
I actually doubt i will mount the screen in my dash.
I am going to mount the CD drive in my dash above my stereo though.
Brian
Ok..thanks for the feed back you two. I'll experiment on some old pieces first before i mess up my dash.
I just read this whole thread and this looks like a very good idea. I have never fabricated anything in my life and my screen and metra kit should come in the mail tomorrow. I think I am going to take this route even though I was going to have my friend who is experienced with fiberglassing help me.
My dad does construction/plumbing/tile setting/electrical work so I already have acetone and ABS pipes available to me and Longs/Wallgreens is right around the corner for the condiment bottles. We also have a router so shavings will be incredibly easy to get.
I will be sure to take and post pictures of my process if I do choose this method.
The ABS Acetone mixture can be as thick or thin as you want...just vary your ratio. I used some thick stuff to get the general shape then used thinner stuff to fill in any air pockets I got from working too fast.
1997 VW Jetta GLX VR6
old HP MP
PIII 600 or so 256 MB
7" Xenarc
and some plywood holding it all together
My Project
That makes sense! I'll definitely give that a shot. Thanks!
I think for just glueing bits together, that's a great idea. I can't believe I've never thought of doing that myself. I chose fiberglass to work with because I was actually creating new parts. Achieveing a nice curved panel where there used be all sorts of pocket 'n' junk is the true calling of fiberglass.
AutoPC: M10k, WinXP, gps, wifi, 80GB HD, dvd-RW. SB mp3+
MediaEngine front end, map monkey, netstumbler.
gps mouse is on the fritz.....stupid technology
I'm going to learn the art of fiberglassing soon. Can't wait to itch! But the results i'm sure look great.
